Question about Hampton Bay HL52QV-P-3LC14 Brass Landmark III Fan
Missing bracket to mount fan to electric outlet box
I don't know what it looks like, but it would be an adapter that would screw to the outlet box and then to the fan base.
  • 34 Answers
They sell universal fan hanger brackets at home depot for a few dollars. they will be in the same section as the lamp parts.
Posted on Sep 09, 2009
Yep. discontinued
Posted on Sep 19, 2011
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Installing a Hampton Bay Trieste ceiling fan, and I don't know where to locate the remote receiver. It doesn't seem to fit in the canopy or the fan base. It is rectangle shaped about the size
If it's a thin rectangular receiver (probably has UC7067 printed on it) It "slides" into the mounting bracket up by the electrical box. If this doesn't help you can call toll free 1-866-600-3267 at http://www.fanmanlighting.com/default.asp and ask for Jack Jr
Oct 15, 2012 | Hampton Bay Ceiling Fan. Trieste 52 in....
Hello, I have a ceiling fan 44F8, motor C0006, but I don't have the screws to intall it on the ceiling nor the screws to attach the.. well not sure what the name is..perpelars? Where can I buy the...
betancurf - If you're missing that many parts, you're also going to need the mount for the ceiling receptacle box, and hopefully that receptacle box will support the fan while it's running.
The screws for the fan blades can be found at most home centers that sell ceiling fans. As can all the other mounting parts you'll need to properly install it.
Jun 09, 2011 | Heating & Cooling
Wobbles......5 ceiling fans
Several things can cause a ceiling fan to wobble. The most of common of which is loose screws in the fan blade irons , that attach to the fan's motor. Just one loose screw can cause significant wobble and at times, an annoying noise. The other, which is more serious, is that the plastic ball on the top end of the down rod, that attaches to the electrical outlet bracket, is improperly installed. It generally has a groove in it, that must be installed so that it fits over the tang in the bracket. The tang keeps the ball in place. To inspect it, you will need to loosen the screw on the ceiling cowl, so that it slides down the down rod. If the ball is not resting in the bracket properly, lift the fan up by the down rod and put the plastic ball in the proper position. Be sure the wall switch for each fan you work on is turned OFF, before attempting in inspection or repair.
While you're at it, make sure the ceiling/electrical box bracket is tight to the the ceiling and is level,
Hope this helped you troubleshoot and solve the wobbly problem. Please let me know. Thanks.
Jun 01, 2011 | Heating & Cooling
Having trouble taking down the fan have removed the light and the blades cannot get the motor assembly down
Don't know which brand ceiling fab you have, but almost all mount the same way. You have completed most of what needs to be done. So, now you need to remove the ceiling cowl, that slides up and down on the down rod. There should be 2-3 screws in the top outer edge of the cowl. If you remove those, the cowl will slide down the rod. After that, unscrew the wiring nuts, that connect the fan's wiring to the house wiring. Don't forget to disconnect the copper ground wire, too. Then the ball on the end of the down rod shaft can be lifted out of the ceiling bracket.
MOST IMPORTANTLY, DO NOT ATTEMPT TO DISCONNECT ANY WIRES UNTIL THE CIRCUIT BREAKER FOR THAT CEILING OUTLET IS TURNED OFF. DON'T JUST RELY ON THE WALL SWITCH BEING OFF.
Hope this helped you in the removal of the ceiling fan. Please let me know. Thanks.
May 23, 2011 | Heating & Cooling
About how long will it take to replace the radiator?
About 2.5 hours
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  • Tools Required
  • J 38185 Hose Clamp Pliers
Removal Procedure
110563917
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
  1. Remove the battery.
  2. Remove the air cleaner assembly.
  3. Drain the cooling system.
  4. Remove the right and the left engine mount struts. Refer to the following procedures:
    • Engine Mount Strut Replacement - Right
    • Engine Mount Strut Replacement - Left
  1. Use J 38185 to remove the inlet hose clamp from the radiator.
  2. Remove the inlet hose from the radiator.
  3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
110563918
  1. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
110563919
  1. Remove the cooling fan shroud bolts.
  2. Remove the coolant reservoir hose from the radiator overflow neck.
110563920
  1. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  2. Disconnect the engine cooling fan motors electrical connector.
  3. Remove the cooling fan motors electrical harness from the fan shroud clips.
  4. Remove the cooling fan shroud.
  5. Remove the bolt from the condenser tube support bracket to the radiator.
  6. Use J 38185to remove the outlet hose clamp from the radiator.
  7. Remove the outlet hose from the radiator.
  8. Disconnect the transaxle oil cooler pipes from the radiator.
  9. Tilt the top of the radiator rearward.
110564721
  1. Remove the condenser hold down bracket (1) from the radiator.
  2. Remove the air deflectors from the top of the radiator.
  3. Lift the condenser from the mounting tabs on the radiator (2). Position the condenser aside.
  4. Remove the radiator.
Jan 02, 2011 | 2004 Chevrolet Impala
No outlet box in ceiling, it has a hook is there a special bracket, my home was built in the 1940s and the ceiling fan in the kitchen was hung with a hookin the ceiling, there is no electrical outlet in...
They sell brackets at home stores, but I have nailed a 2x4 between ceiling joists & mounted an electrical box at proper height. If you aren't good with electrical, get an electrican to run power for you.
The hanger must be SOLID & the wiring GOOD.
Apr 25, 2009 | Hampton Bay 42 In. Antique Brass...
Where do i put remote reciever for fan install.
I'm not completely sure what the fan mounting bracket (that screws to the electrical box) looks like on this model, and I'm not sure what type of remote you have, but remote receivers usually slide in between the ceiling and that bracket (slide in with antenna wire first). Or the other type goes inside the very bottom of the fan, the part where a light kit gets attached (these receivers look like a donut).
Jan 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Jan 16, 2008 | Dryers
Hampton Bay HL52QV-P-3LC14 Brass Landmark III Fan Logo
160 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
