E069 CODE ON IR7095 COPIER
E069 code on canon ir7095 copier. we have changed whatever you can think of. replaced AC/DC HVT. replaced transfer assembly. checked for the ground plate on the fuser. you name it, we have done it. the machine comes out of warmup and start making copies. 100 page or so into it will go to 69 code. very frustrating. please help.
  • 37 Answers
Most often I find a bent bearing holder in the fuser causing this, if that is the case you will see the wear marks on the upper roller.i have alsoseen a cracked or broken collar on the fixing roller causing this. I have also had a bad connection on the back of the fuser cause this. and on one instance a pre-transfer corona assy fixed it. most likely it is in the fuser, I have ran into this close to a hundred times and most of them have been in the fuser.
Posted on Sep 08, 2009
How do I fix IR7095 - error E733-0001
A fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB and the Causes The connector has poor connection. The DC controller PCB is faulty.
Connector, DC controller PCB Is the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB normal? Correct the connection. YES: Replace the DC controller PCB. or
check and make sure the DIMM is seated firmly
Check any ribbon cables , they always look connected / re set
May 05, 2016 | Canon Office Equipment & Supplies
Canon ir7095 error code E-65
The high voltage output has a fault(primary charging assembly.Remove and than mount primary charging assy.,check for soiling.Disconect and than connectT601,J723 of the high voltage DC PCB.And the last option-replace HV-DC PCB
Oct 22, 2014 | Canon Office Equipment & Supplies
Error code E102-01 for canon ir7095
E102 - A read error has occurred in relation to the laser scanner unit EEPROM data.
theres a good chance that what is needed here is the laser scanner unit has a Beam Detect mirror and sensor and after time gets coated with foreign particles(dust) cleaning these mirrors/sensors will probably allow the unit to work again- this job should only be undertaken by a qualified service personnel, as more damage than good could be caused. if the laser scanner unit appears clean then iut will need replacing.
Jan 16, 2014 | Canon Office Equipment & Supplies
064 code
Symptom
E064 is indicated on the control panel. The error description is: The presence of a high voltage error is communicated by the composite power supply. The output for primary charging, developing, or transfer has deviated from a specific level of voltage.
Cause
* Adjustments in Service Mode are Incorrect
* Transport Assembly is Not Engaging Properly
* Dirty HVT Contacts for Developing Assembly and Charging Rollers
* A Paper Clip on HVT Contacts or Developing Assembly
* Faulty Transfer Roller
* Faulty Static Charge Eliminator
* Defective Composite Power Supply
* Defective DC Controller PCB Assembly
Action
1. Check the values in Service Mode and make sure they correspond to the Service
Label. If the copier receives a spike or surge through the 240V line these values can change (can also give you blank copies). Take particular note of the Dev Bias
setting. [COPIER > ADJUST > DEVELOP > DE-DC]
2. Make sure the Transport Assembly is engaging properly. The Transfer Roller should
make good contact with the drum. Check condition of screw (XB6-7501-007) and
Pressure Plates (FB5-4816-000 & FB5-4817-000) for the Transport Assembly.
3. Clean HVT contacts for Primary/ Transfer Charging Rollers and Developing
Assembly. Inspect for any paper clips.
4. Replace the Transfer Roller (FF6-0104-000).
5. Replace the Static Charge Eliminator (FF5-7246-000).
6. Replace Composite Power Supply followed by DC Controller PCB Assembly
Thanks
Dec 17, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Ir7095 error code E000004-0001
If you have more than 200 000 prints need to be replaced: Fixing assembly 230 V......... FM2-0174
Inspect thermistor and switch on FIXING UPPER FRAME ASSEMBLY
Oct 09, 2012 | Office Equipment & Supplies
ERRCODE 00064-0000
Did you try to think about replacing DC Controller (FG3-1998-020) i
Jun 30, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
What is error code E000068-0000 on a canon ir7095 and how do I fix it?
first thing you need to check is the primary assembly & transfer assembly maybe there is a broken corona wire or the primary assembly or the transfer assembly is dirty
Dec 06, 2010 | Canon imageRUNNER 7200 Copier
I recieved Code E069 in my machine
hi
error E069 is high voltage leakage?clean transfer unit and separation corona,
Jan 15, 2009 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
1,002 people viewed this question
jasbo
jasbo
