Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9250ML2 not draining - pump runs noisey
I am on my third pump for this machine (over the last four years) and I replaced the last one myself about 18 months ago. This time, the washer will not drain and the pump runs, but is very noisy. The washer has not displayed any error codes. I checked the drain trap in the pump and it was clean. I removed the pump motor from the housing, turned off the water valves and then ran the drain cycle (used the repair diagnostic cycle - code 06 in the repair diagnostic manual) and the pump impellor spun, but was very loud. I disconnected the drain hose from the pump and has able to blow air into the hose and hear water bubbling and didn't feel any obstruction.
Do I have a bad pump, even though the motor spins? Or, is there some other problem?
I dont know but if you find out will you share it?
Posted on Feb 01, 2010
Whirlpool front loader washer will not do the last drain and rinse cycle. Cleaned the drain pump but still doesn't work. When it gets to the last cycle it just beeps every couple of seconds.
check the pump motor if running when the program is in drainning time,if not!check the power going thru the motor or if theres is, or check the motor winding if its okey!
Oct 03, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Code "F02" sometimes pumps out water sometimes
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Here's the handy Hippy with a nice video
Here is a Duet HE washer service manual
Thanks for using FixYa
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9250ml2 is not spinning does this model have a drain trap to clean?
Welcome to fixya.
Try this link of my solution for this issue...it is very common and locating the filter is part of the remedy for these faults so it should serve helpful for you too.
http://www.fixya.com/support/t7367730-f_21_error_displayed
Let me know how it goes and if you require further assistance.
Thanks for choosing fixya. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
or kinked.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet whirlpool ghw9150L - run diagnostics and goes to 03 then f/h
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 25, 2009 | Whirlpool GHW9150 Duet Washer
HELP WHIRLPOOL DUET
post me your email here and
I will send you a PDF of the service manual
Thanks Gary
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
271 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
