Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
I have a porter cable 4.5 gallon 150psi air compressor when it gets to 150 psi the air release valve opens
  • Anonymous Mar 27, 2014
    It does not seem to complete the tank fill
  • 143 Answers
That is what the relief valve is set at, you need to
either increase the pressure on the relief valve or
reduce the pressure on the pressure cutout switch. Stephen
Posted on Sep 06, 2009
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
Porter cable the compressor regulator is always at 0, the tank is at 150psi but no air at the outlets
Always at zero,like the regulator is broken?
I would assume that you never set it to whatever
pressure you want to use
Jul 31, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to www.factoryauthorizedoutlet.com to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
When I plug in my Porter Cable job boss compressor it barely turns over and usually blows the breaker. Any thoughts?
If this happens with no pressure in the tank then you may have a bad start capacitor on the motor.
If this only happens after the tank is full of air then you need to make sure the check valve is working and releasing the head pressure from the lines.
Sep 27, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
UNLODER DOESNT RELEASE BOGS DOWN BLOWS FUSE
the non return valve to the tank is certainly the next thing to look at .
Jun 06, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
May 23, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Wont pressure up
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
179 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
