Question about Poulan Garden
Need to reassembly my fuel line could you please e-mail me the assembly instructions to look at.
    President:
  • 2,220 Answers
Almost all Poulan models are listed here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Look around and find your saw. The IPL (exploded parts list) is only diagram I've found for part placement and routing. GL
Lou
Posted on Sep 07, 2009
How to replace fuel line on a Mac 10-10
If its a Mac 10-10 it is old enough to need a thorough major component disassembly and service. Keep your smart phone handy and take a few dozen pictures as you disassemble each component until you get down to just the engine/clutch assembly. Use compressed air and possibly a spray can of carbuetor cleaner (follow all the safety instructions) to totally clean the impacted sawdust and oil from the clutch, magneto, cylinder and the removed components.
With the new replacement fuel line and impulse line on hand, start the reassembly referring to the pictures in reverse order....
Sep 25, 2015 | Garden
Have had generator in storage, Makita G1300R. What do I need to do repair wise to get it to start after about ten years in storage??
Remove air filter assembly. Disconnect fuel line from carburetor and drain old fuel into suitable container to discard. Fuel Shut Off in the On position. If fuel has gelled up in the tank or lines, add small amount fresh fuel in fuel tank, swish around several times and flush until clean.
Loosen and remove Carb Mounting nuts, throttle linkage and spring (note the position). Carefully remove Carburetor and very carefully remove gaskets (do not discard until completion of final reassembly)
Disassemble Carburetor and thoroughly clean with appropriate cleaner and immediately following with compressed air. If thick gelled old fuel is present, soak disassembled carb in cleaner overnight before using compressed air is highly recommended.Reassemble carburetor, replace gaskets and install Carburetor (Reverse dis assembly) Inspect and replace air filter upon reassembly.
Inspect spark plug and replace (do not over tighten).
Add fresh fuel and perform start procedure. Initial start might take a few pulls but should start right up.
Sep 23, 2014 | Garden
Water in injectors
Yes, I would say you have water in your gas. You will have to drain your tank to get rid of any bad gas. Pull out the pump assemble, disassemble the pump and clean all internal parts and lines and reassemble and reinstall. Then flush out any water/bad gas in your fuel lines to the injectors. Reassemble and put good gas into the tank.
Mar 22, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Lost assembly instructions for my Magellan Navigator Tent 20' x10' Deluxe Family Cabin Tent. Can you help me? thanks
Hello, I have the assembly directions for the 20' x 10' Magellan Navigator Deluxe Family Cabin Tent. If you still need them let me know and I can send you the scan. It is a 2MB scan. E-mail me at swx4@sbcglobal.net and please put "magellan tent"in your subject line.
Scott W.
May 17, 2011 | Sport & Outdoor - Others
How do i replace the right rear turn signal bulb of my 2002 Buick Lesabre limited?
Hello! Working from the trunk:
1. locate the 2 retaining knobs that you fasten the trunk cargo net to and remove them...Look for the hard plastic trunk liner near to and inside of the rear light assembly. Unscrew the knobs.
2. Pulling back the plastic liner, locate the 4 studs (threaded posts). 3 will be located vertically in a line, the fourth, outboard and lower. Using a 10mm wrench(small), remove 3 of the 4 nuts fastening the light assembly to the body. DO NOT remove the lowest nut of the 3 in a vertical line, as this does not fasten the light assembly... Working from the rear of the car:
1. Hand pull the light assembly from the car body.
2. Remove bad lamp. Twist lamp socket and pull out of assembly. Pull lamp and replace with #3057.
Reassemble:
1. Test light prior to reassembly.
2. Ensure Gasket material for assembly and studs is intact, this keeps water/dust out and dampens movement (prevents rattling and increases the life of lamp).
3. Use Reverse instruction for reassembly.
Guru.....Saailer
Jan 04, 2011 | 2002 Buick LeSabre
Have a weedeater gt1 15 trimmer how do u get the gas tank apart to repair the gas tubing
You will not need to remove the gas tank or take the gas tank apart. Follow these instructions:
1. Disconnect the fuel line from the carburetor. You may need to cut the line pull it off.
2. Push the fuel line back through the gas tank. At the end of the fuel line is the fuel filter/weight that should be moving around within the gas tank.
3. You should be able to pull the filter/weight out of the fuel tank through the neck using a needle nose pliers. Insure the fuel filter is cleaned out before you re-assemble.
Note: The fuel line that you use as a replacement must be the same diameter of the fuel line you are removing. If you cannot find the fuel line at your local mower shop, try Lowes Hardware as they do stock it in the lawnmower section.
To reassemble: Take about 7 inches of correct fuel line and cut a 45 degree angle cut at one end. That end is threaded back through the tank through the small hole. Push as far as you can and then reach in and pull it to the neck. Cut the straight, attach the filter/weight and pull the line back through.
Sep 28, 2010 | Poulan Garden
How to install a few pump that's in the gas tank
remove exhaust system from cat converter back, disconnect fuel lines, disconnect electrical connector remove straps that hold tank up to car remove fuel filler and vent hoses from tank drop tank top of tank remove ring that holds fuel pump assembly in tank. you have to manupliate the assembly out of the tank, its a tight fit, be careful not to break/bend the fuel level sensor. remove fuel lines on top of pump assembly before removing assembly. replace fuel filter also make sure you are careful on reassembly if there is a leak ses light will come on w/evap code (I just done mine (176000 miles)
Aug 20, 2010 | 2001 Saturn L-Series
Left turn signal bulb replacement
In about 10 Minutes:It's easier than it looks.
1. locate the 2 retaining knobs (doohickeys that you fasten the trunk cargo net to) for the Hard plastic trunk liner near to and inside of the rear light assembly. Unscrew the knobs.
2. Pulling back the plastic liner, locate the 4 studs (threaded posts). 3 will be located vertically in a line, the fourth, outboard and lower. Using a 10mm wrench(small), remove 3 of the 4 nuts fastening the light assembly to the body. DO NOT remove the lowest nut of the 3 in a vertical line, as this does not fasten the light assembly. DON'T LOSE THE NUTS OR WASHERS.
Reassemble:
Sep 29, 2009 | 2001 Buick LeSabre
Garden Logo
165 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
