Question about Bosch 22 in. SKT5102 Free-Standing Dishwasher
Have a blocked pump on Bosch SKT5102GB tabletop dishwasher. Need a schematic diagram or something to see how to dismantle and clear. Can anyone point me in the right direction. Thanks! John
  • 125 Answers
SOURCE: Bosch dishwasher stuck on "1"
YOU MAY NEED A CONTROL BOARD OR A HEATER. THERE IS A CONNECTOR WITH A RED AND GRAY WIRE, THE RED WIRE IS THICKER THAN THE OTHER RED WIRES. IF YOU HAVE 120 VOLTS ON THERED WIRE THE CONTROL IS GOOD. YOU NEED A CLAMP ON AMP METER TO TEST TO SEE IF THERE IS AN AMP DRAW ON THE RED WIRE WHICH WOULD TELL YOU THE HEATER IS WORKING
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: SKT5102/gb1 - not pumping out
I had a problem that seems to be related, but it came out that the pump was blocked. I had service to open and remove a small plastic clip that had came into the machine accidently. I do not recognize that water was pumped back as you explain but if the water is not emptied may be this is the result...
Posted on Jan 02, 2009
  • 457 Answers
SOURCE: Bosch dishwasher soap dispenser
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
Posted on Feb 26, 2010
  • 457 Answers
SOURCE: The water will not clear out of my Bosch Dishwasher
you have to free the propellor to get it to free spin. there is a screw at the base this will give you access to the propellor.its a torc screw. when you get to propellor spin it with your hand and it will free up.
Posted on Mar 03, 2010
ginko
  • 19396 Answers
SOURCE: Hi I have Bosch SKT 51 tabletop dishwasher, all
Hi.
The problem is likely the switch itself. the switch should be part of the control pad, which I think is a single spare. A test on the switch can be done by reading impedance on the control pad wiring harness while operating the switch. If the problem is not the control pad, then the problem is control module. Control module and pad are often sold together as a single control assembly kit.
Spares for this counter-top dishwasher are not available online. You will need to call directly the phone number listed on your Bosch owners manual to check price and availability.
Regards.
Ginko.
Posted on Mar 27, 2011
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
Pumps water in don't wash and pumps out again
Not sure whether a schematic will help unless you have some understanding of the location of the components. It would help if you are able to clarify what you mean by pumping in. Usually you should hear the water inlet valve turn on to let water in. Then the wash motor should run to churn the water around and then the drain pump should drain the water out. What is happening is the dishwasher is leaking water as soon as it fills. This causes the flood switch to turn on and that triggers the drain pump to empty the water. Usually Bosch dishwasher have an inline water leakage detector. Check under the sink where water inlet tap is located. There is a device connected through which the water get in. The hose is detecting leakage. Need actual model number of the dishwasher to investigate.
Apr 07, 2014 | Bosch Dishwashers
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
Schematics/Diagram for Bosch SHE68M05UC/50
The last two Bosch Dishwashers I have owned, the detailed schematics were rolled up tight and placed in behind the left front foot rest.
Jan 18, 2013 | Bosch Evolution 800 SHE68M05UC Stainless...
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishwasher doesnot drain
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Jul 24, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch 22 in. SKT5102 Free-Standing Dishwasher Logo
245 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
