Question about Whirlpool Dryers
My whirlpool dryer heat up. But does not spin.
My 8 cycle heavy duy super capacity whirlpool dryer heats up. (model: SEDS800JQ0). But does not spin. It is a 6 year old unit
  • 304 Answers
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Posted on Sep 07, 2009
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
Nov 28, 2011 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
After drying for 75 minutes timed cycle, my clothes are still damp. I also cannot get clothes dry on the normal cycle at all.
Things to check:
Make sure the dryer is heating up
Make sure the lint screen is clean
Check the vent to make sure it isn't obstructed or plugged (this is the pipe that goes to the outside)
Make sure the unit isn't overloaded
Check the spin cycle of the washer - if it isn't spinning out enough water for the load, the dryer can't make up the difference - sometimes this is as simple as a plugged discharge filter on the hose that goes to the drain.
Dec 23, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Apr 26, 2009 | Whirlpool LER5636P Electric Dryer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
318 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
