Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
Gateway Profile 4 with two hard drive failures
I have a gateway Profile 4 Model # 3501400 that has failed two hard drives. ANy suggestions as to why. I have replced the fan also. We were told to leaave the computer on at all times instead of shutting it off, could this add to the failures?
    Problem Solver:
  • 15 Answers
How do you know 2 hard drives have failed, have the hard drives been fin in another computer.
most likely the OS is corrupt on the disks caused my another hardware issue, most likey Motherboard IDE/sata controller.
Posted on Sep 07, 2009
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
My Gateway GT5404 Freezes
1. your hard drive may be at what is called the "end - of - life"
2. I suggest that you try to backup important files if you can get into the pc screen again.
3. PC freezing is sometimes due to a failing power supply, a failing hard drive, and or a depleted CMOS battery.
May 15, 2010 | Gateway GT5404 PC Desktop
Hard drive status: faild model: WDC WD2500JS-22NCB1 is there a way to check this drive
You can open the device manager and see if it says "this device is operating correctly" ...go to start, right click computer, Manage, and then on the lh side click device manager. You can also go into setup when your computer is booting (this is your bios) and see if there are hardware tests in there...many bios's have a hard drive test in there. But, if you got an error that says your hard drive failed...your hard drive is more than likely crashing if it's not gone yet, I would back it up. Usually they get a SMART failure before they are actually gone. Yes, the detection programs now detect certain hard drive failures, and can detect a failing hard drive before it's all the way gone...this is very helpful because it gives you time to save your data.
Jan 13, 2010 | Gateway Computers & Internet
BLACK SCREEN WITH CURSOR NOW WITH A BLINKING LINE
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Dec 03, 2009 | Gateway P-6313 Notebook
I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
May 12, 2009 | Gateway Profile 5 PC Desktop
I installed a new hard drive in a Gateway 4XL.
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Mar 07, 2009 | Gateway Profile 4 XLb PC Desktop
Profile 4
Download some free hard drive testing software, like seagate tools,from:  Seagate.com  or another had drive manufactor. They run from a disk w/o windows . If the hard drive checks out try reinstalling the system. Another quick test , for conformation is to hook up you monitor to anther computer just to make sure it is not the monitor. It rarely is.
Mar 01, 2009 | Gateway Profile 4 All In One (MPN...
MY GATEWAY PROFILE 4 ISSUES A PROBLEM WITH THE HARD DRIVE.
Bad news. Your hard drive has had a SMART failure and subsequently crashed. If your data was important, I would get the computer to a skilled professional as soon as possible. Ideally, you can get them to make an image of your drive. That will get you back to right before the crash. If they can't do that, there are data recovery places like gillware.com that can help you out for a flat fee.
Jan 25, 2009 | Gateway Profile 4M PC Desktop
Hard disk failure
What exactly does the error say?
The safest thing to do is to stop powering up the hard drive. Get a new hard drive and adapter cable to pull the data off the old hard drive (secondary) and onto the new hard drive (primary) after the new hard drive has been formatted.
If you don't feel you can safely do that, you may want to seek the assistance of someone who can or a company that provides hard drive recovery services.
A hard disk failure error typically indicates the hard drive has (or is about to) fail and become useless.
Jan 03, 2009 | Computers & Internet
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
214 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
