Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
SONY 60" KDF-60XS955 power goes off and on every 30 sec
  • 3 more comments
  • albertito Dec 12, 2007
    green power on light turns on for about 2 mins then goes blinking, sound and picture goes out, then turns on again in less than 1 min..then turns black again..it goes on forever....pls help
  • Rupen Dec 21, 2007
    Hey I just changed my XL-2200 replacement lamp myself and now my TV is back to normal............hurray.................just cost me $ 200.00
  • Anonymous Jan 15, 2008
    I had the same problem and then the same solution (replace the bulb). But I noticed the old bulb had dust over the fine screens where the cooling air blows through the bulb. I blew out the dust and Bingo the old bulb works fine and on/off problem had gone away.
  • Anonymous Feb 02, 2008
    Have the same problem - Turns off and on every 30 sec.
Have the same similar problem..only thing is the lamp bulb light error light hasnt gone on...all i get are the green flashing lights.did u guys experience the same thing?
Posted on Jan 24, 2008
..got the lamp changed too..back to be where it was before, working perfectly good...saved a lot of mone from having it serviced at home...thank you all for the info....
Posted on Dec 21, 2007
How do i fix my tv
I had the exact same problem. Thought I could fix it by replacing the thermal fuse . . . no luck there. Problem continued. After tons ( I do mean tons) of research, I found the problem to be a temperature sensor. Makes total sense ! ! ! The tv is trying to come on, but the temperature sensor is bad, telling the tv that it is too hot to operate, so it turns itself off - only to try & come back on 30 secs or so later. Hard to fix unless you know your way around tv circuits. Took me bout 3 hrs total.
Nov 08, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tip
Sony KDF-60XS955 Manual Download
Download Sony KDF-60XS955 HDTV Manual
Models: KDF-60XS955 / KDF-55XS955
Have you misplaced your Sony KDF-60XS955 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Sony KDF-60XS955 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDF-60XS955 HDTV manual.
I hope that helps.
__________________________________
Sony KDF-60XS955 Service Manual Download
on May 08, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tip
Download Sony KDF-60XS955 HDTV Service Manual
Have you misplaced your Sony KDF-60XS955 HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Sony KDF-60XS955 HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDF-60XS955 HDTV Service documentation.
I hope that helps.
_______________________________________________
Sony KDF-60XS955 LCD Projection HD Grand Vega. Turns itself off every 30 secs or so. Flashes green light 32/33 times. Comes back on with picture but no sound. Then sound comes on at green flash 37 and...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Feb 20, 2018 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
123 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
