Question about HP Photosmart C6180 All-In-One InkJet Printer
After scanning a document and try to print it, it
After scanning a document and try to print it, it prints the whole page black
Scans document but will not print
If you haven't tried this yet..on your print page there's a task bar that prompts you to choose your printer..make sure you choose the printer your using and then simply click PRINT..
Mar 22, 2014 | HEWLETT-PACKARD Envy 5530 built-in WiFi HP...
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
CANON PRINTER MP560 WONT PRINT IN BLACK
This is seems to be weird issue you are facing with the printer. I would like to know what is the application you are trying to print from ? Is it Microsoft word etc ? Try to type something in Notepad and print and check if the black is printed.
If you are able to print from Notepad then probably it there are chances the application you are tying to use is corrupted and might need to uninstall and reinstall
Regards,
Suhail
May 14, 2012 | Canon Office Equipment & Supplies
When scanning or copying a document it prints a black page
IN NO TIME AT ALL, YOU WILL RUN OUT OF INK.
SUGGEST YOU REMOVE PROG RESTART, THEN SETUP AGAIN. GLITCH?
Nov 15, 2009 | Dell V305w All-In-One R840635AU InkJet...
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
HP Laser 2200 Cannot print one page or a range from a document
Dear,
I think the problem is in the printer setting, so just uninstall the Printer(Driver). Restart the PC and reinstall the driver.
It may solve your problem.
Regards,
Rakesh Kumar
Apr 09, 2009 | HP LaserJet 2200 Printer
Lexmark won't print whole document
Seems an unlikely solution, but I upgraded from Office 2003 to Office 2007.
As soon as I did this, I was able to print multi page documents. Go figure!
Apr 09, 2009 | Lexmark X4250 All-In-One InkJet Printer
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Scanning
u can scan it as a document and just adjust the settings from the computer to scan it in as colored document
Jul 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
