Question about Health & Beauty
I enter test strip, get reading E 6 I've had the meter for years and have no instruction booklet. Thanks
Please specifiy the make and model. Thanks.
Posted on Sep 06, 2009
02 Cavalier I have no headlights have parking lights brake lights turn signals I also have daytime running lights anybody have an idea
Could be the light switch is bad , but that would be just guessing ? And you don't want to replace parts form a guess posted on here !
The way to find the problem is with electrical testing , using a volt meter , wiring diagrams an leaning how to do automotive electrical testing , how to read an use wiring diagrams etc.. Testing B+ voltage to the headlamps an the ground circuit using voltage drop testing . That is if you want it fixed right .
Electric Testing Techniques You Need to Know
Elec Lesson 6 AC Diag 1
How to read an electrical diagram Lesson 1
Find a wiring diagram at http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter vehicle info. year , make , model , engine size . under system click on lighting then under subsystem click headlamps . Buy a volt meter an test the circuits .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Apr 04, 2017 | 2002 Chevrolet Cavalier Coupe
My easy touch meter is reading way to high how do I fix it?
How do you know it is reading watch too high is my first question..MAKE SURE IT IS NOT YOUR GLUCOSE THAT IS READING HIGH..the tester should have a small bottle of testing accuracy with it..there are number scales on the side of the strip container and on the test bottle use a strip and test it..if it reads on or between the numbers the strips and tester is ok..if it does not, try another from another strip from different container..if it still reads wrong..your tester is faulty..good luck..
Apr 23, 2014 | Easy Touch No Coding Glucose Monitoring...
E-5 error code
  • Blood was applied to the test strip too soon. Slide and release buttonicon.gif to turn off the meter and release the test strip, then turn on the meter again. Repeat the test, waiting for the flashing test strip and blood drop symbol before touching blood or control solution to the end of the test strip.
  • The test strip was bent before the test started. Repeat the test with a new test strip.
  • There is moisture in the meter. Slide and release buttonicon.gifto turn off the meter. Let the meter dry at room temperature.
Apr 03, 2014 | Accu Chek Compact Plus Blood Glucose Meter
WHEN I TRY TO CHECK MY BLOOD SUGAR, IT EITHER SAYS ERROR 2 OR ERROR 5
Error
1 too hot or cold
2 sample not detected or using wrong strip
3 used strip, stip out too long or blood on top of strip
4 meter error call for help
5 very high blood glucose (600+)
6 strip removed during test
8 memory error, result not recorded
9 communication error.. call for help
hope this helps, please note that online manual is available if you search for it online, and this is why it is immportant to keep all instructions in a safe place.
Jan 13, 2014 | Walgreens Trueresult Blood Glucose Meter,...
ERROR
Read instruction booklet, all error codes shouild be in it somewhere, uually towards the back of each language section.
Dec 09, 2013 | Arkray USA Pocketchem Ez Blood Glucose...
Error appears
Did new test strips come with a code key (small plastic piece that fits into machine) If it does replace chip in machine and use new one. Instructions will tell you more.
Nov 20, 2013 | Aqua Chek Trutest Digital Test Strip...
User guide for optium EZ blood glucose tester
set of instructions should be in box, or read machine instructions
Oct 24, 2013 | Medline Abbott Diabetes Care Glucose...
How do i also clear off all of these dangerously high blood sugar readings from the glucocard vital blood glucose meter?
Directions should say.try taking the battery out eat more veggies and exercise I've had it 41 years. God bless
Feb 25, 2013 | Arkray GlucoCard Vital Sensor Blood...
Change Time
Set Date and Time Display
Press Trsf and then dial 505
Enter the new time and date using the format
Day of week 0 sunday 6 for Saturday
month - 01 for Jan. and 12 for December.
Year - last two digits of the year
hours enter # range 00-24
minutes enter range 00-59
Verify time
press trsf to store and exit or press SPK to store and advance to the next program
Nov 10, 2007 | Samsung Phone PDCSLCD12B
Health & Beauty Logo
12 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
