My restor disk douse not work
My pc is slow i have never resored it i turn of the pc with the disk in the drive i say yes to all it asks and stops at 20 per sent and all i get is a black screen with a dot flashing help me to get a new restore disks
    Sergeant:
    Champion:
  • 326 Answers
What kind of pc?
What os?
How old pc?
Does system come up without restore?
If pc is slower than normal, did U clean and defrag?
Posted on Dec 09, 2007
Im trying resore my acer back to factory settings
Did you press 5 times
If you do NOT have a copy of this disc, skip to step 3 for further instructions. Once you restart your computer, a screen will appear with the words. Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings. Follow the on-screen prompts to finish the installation. Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again. Restart your computer to complete the restore. 3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk. Unplug all external devices and restart your computer. When the loading screen comes on with the Windows logo, press Alt+F10 together five times. This will bring up the system restore menu. Follow the on-screen prompts to restore your computer back to the factory settings Hope this helps.
Jan 20, 2013 | Computers & Internet
How to master reset my emachine desk top ? Its very slow
To do a factory resore and remove all data look at the boot up menue it will tell you to push a key generally F10 or F8 to start factory restore.
However you can fix your slow pc with out doing that by running the command "msconfig".
Go to "run" from the start menu
click run and type msconfig in it
next go to that startup tab and disable all.
next look for sound and video drivers (nvidia, ati)that may need to be on. and turn them on
(Things like adobe reader and ms office can be safely turned off and will still run fine)
now reboot you should have a mutch faster pc.
Don't forget to rate.
May 18, 2011 | E-Machines eMachines Desktop PC
I get this problem and can't get past it help please Unmountable_boot_volume its a problem with the recovery system a blue screen for dell inspiron 2650
I sure hope you kept a recent backup. Something has gone terribly wrong in there. If you didn't keep a recent backup, do you still have the Windows setup disk(s), or the Recovery disk? It sounds like you will need to do one of those. STRONG ADVICE_ DO NOT start to run a Recovery or Resoration disk NOR a backup and then stop it part-way done! I did that recently, and it took me 3 months to find a solution. It deletes all your partitions. Then nothing will work without much research and work. Once you start a recovery from a disk or a backup, let it finish! It may take awhile, but it's worth it. Don't panic. Just do a backup restore or a restoration disk, and any lost data, will be lost. People call using the Restoration CD a "reformat". It gives you a fresh install of Windows. Try to always keep a recent full partitions backup, it's worth it's weight in gold. Feel for you!
Dec 21, 2010 | Computers & Internet
Hard disk corruption. says press x to resore but wont load past 18%
Try this:
turn on ps3 press x to restore on 0 % quickly pull out hdd. then wait may take up to an hour a message will come up to formate hdd. put hdd back in and press yes to format this process worked with in seconds for me but can take longer. it does work but you will lose all saved stuff but online stats will still be on the system. good luck hope it works for u to.
________________________________________________________
or this:
New fix (possibly), and it doesn't take a laptop or a friend's PS3 to do.
Simply remove the hard drive from your PS3, and turn on the console. It should display a screen saying the hard drive will need to be reformatted. Then, plug the hard drive back into your PS3, and allow it to reformat. Your save game data will be erased, but you should be able to use your PS3 again.
_________________________________________________________
whoever has a problem withe their ps3 needing to be reformatted just take out your hdd when the restore comes up, then press x, it will take a will before the ps3 tells u to insert a hdd to be formatted (took me 12 minutes)
good luck
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
How do i remove older versiond of that i have f11 nd to factory s
to do that you have to reinstall clean and format the drive during it ...the actual use of the recovery disk ..or the recovery installation with the F11 is causing storage of junk ...so if you really want a clean installation you have to use a installation disk of the operation system ..and boot from the disk to install and install the drivers and the programs manually after finishing the installation of the op.system ..
so ...first save data...than look for a bootable disk ..and than download or retrieve the drivers for sound .image.devices like lan card and blue tooth ...and when you have all proceed
in Xp case its easier to find a image and make a disk ...but for vista you have to ask someone or to buy it ..
Let me know what you intend to do ..and I will advice you on..
Mar 06, 2010 | Samsung R610-64G Laptop
Programs are slow . looked and removed programs but they still running in background. tried to resore back to factory settings with red floppy disk , however it says bad data when installing then fails....
If you are comforable.with your computers you can:
  1. Start
  2. Run
  3. smconfig
  4. Start up tab
  5. Then get rid of the thing you don't want to start up and run..
  6. Service tab
  7. Then get rid of the thing you don't want to start up and run..
*Becarefull on what you turn off.
**Best rule of thumb you click (#7) Hide all Microsoft Services.
This will give you the chance to delete them if you find them...
If you are not comportable with this, please to do not do it. Have it looked at by someone that is..
I hope this helps..
Nov 03, 2009 | Computers & Internet
How to restore my presario C500
Restore to factory settings? or a System Restore?
For factory restore (All Data wil be Lost), tab the f11 key while booting the computer and enter PC recovery. Go to Advance options and Select the option of "restoring the system back to factory settings". in case u do not go to PC recovery after multilple attempts, there is no partition. Use Recovery cds.
System Resore : All programs > Accessories > System Tools > System restore. Select a date and Follow instructions(No Data Loss)
Oct 04, 2009 | HP Compaq Presario C500t Notebook
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
You responded to my post about removing internal batter for Toshiba Sat.
No dont take the battery out. try this. This works on laptops running XP and Vista.
Turn on the laptop, as soon as you turn it on press F8, this will take you to the system install function saved on a hidden drive on your pc.
Once there it will ask you if you want to do a recovery which pretty much sets the computer to settings for an earlier time period or a system restore. THe restore will reformat the hard drive and reinstall the the original software.
Make sure you pick the system restore function to wipe thedrive. It will ask you if u are sure and it will say something about it being a destructive, again that just means that you will have a factory reset computer again, just like new.
Let me know if i can help you thru
Nov 13, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
