Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yardman self propelled mower model 1619295. Adjustable front wheels attached to a bar underneath. This assembly has come loose and dropped down out of the slots where wheels are. tmanary30 asked this on May 07,2009, but no solution listed. I have the same problem. "Can you tell me what I need to reattach or can you provide a schematic blow up so I can see what to order.
    New Friend:
  • 93 Answers
Go to MTD.com or any of several mower parts stores for an on-line diagram and part numbers.
Posted on Sep 17, 2009
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Self propelled feature stopped functining. I previously replaced the wheels after the gears had worn down. Now I can't get any response to engaging the self-propelled cable.
Have you checked the drive belt? There should be a belt running from the main shaft (above blade) out to the wheel drive. You didn't list model number but I'm assuming it's front wheel drive. There should be a cover over this belt so it might be hard to see from underneath. Also there should be a cover on top going to the drive transmission. If the belt is OK, check to be sure lever is moving the transmission lever.
Oct 30, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
255 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
