Question about Epson Aculaser C1100 Printer
Printer is calibrating for ever and is not ready to print
  • Jose Pino May 11, 2010
    How long is forever? Perhaps waiting enough time you can get the error message to determine exactly what's going on. Did you have more information about the failure?
HP LaserJet Pro CM1415fnw stuck in calibration mode, won't print
there's a few reasons why your printer is doing this - I would recommend the following action:
1 disconnect the printer from your PC ( USB/Net)
2 power off the printer
3 open the top/ front and pull out the process section( where you put your toners)
4 individually remove and then reseat these toner cartridges
close the covers back up and power on ( still disconnected from the PC)
5 allow the printer to come to ready ( if it wont come to ready there may be a problem with one or more of the toner cartridges)
6 print an internal testpage ( press menu , select information, select configuration, select print)
7 whent his prints you know your printer is going to be ok, On your PC-clear ALL the print queue- reconnect to printer and test!
Mar 21, 2014 | HP LaserJet Office Equipment & Supplies
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
HP colour laserjet 1600: I turn on printer and it switches from initialising to calibrating withour printing documents
Does the printer ever come to ready? If not, have you recently changed any of the toner cartridges? We have had cases with generic or refilled toners that will cause the printer to not be able to calibrate.
Apr 11, 2011 | HP LaserJet 1600 Printer
Lines on paper produced by lines on drums new
The link below will provide you with all the necessary information to fix issues related to the HP Laserjet 2420 Printer
HP Laserjet Troubleshooting
Also, try the steps below.
1. Turn the printer off, and turn it on again.
2. Force a calibration by selecting CALIBRATE NOW from the Print Quality Menu.
1. Press example (Select) to enter the MENUS.
2. Press example (Down Arrow) to highlight CONFIGURE DEVICE.
3. Press example (Select) to select CONFIGURE DEVICE.
4. Press example (Down Arrow) to highlight PRINT QUALITY.
5. Press example (Select) to select PRINT QUALITY.
6. Press example (Down Arrow) to highlight CALIBRATE NOW.
7. Press example (Select) to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
3. Perform a cold reset on the printer.
1. Turn the printer on.
2. Watch the control panel.
3. When the memory starts counting, press and hold the green example (Select) button.
4. Continue holding the green example (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
6. Press example (Down Arrow) button once. The control panel will display COLD RESET.
7. Press example (Select). The printer will perform a cold reset and then continue its power-on sequence.
If this issue persists, contact an HP-authorized service or support provider. ( 1-800-474-6836 )
If the Toner is newly purchased and it is because of faulty toner, HP will replace it for no charges.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | HP LaserJet 2420 Printer
My HP color LaserJet 2500L printer will only print yellow or black. All the toners are good and the machine has been re-calibrated and cleaned but it will not print full color
Print cartridges might be improperly installed. Remove the print cartridge for the color that is printing inconsistently and reinstall it. im sure you tried this already, but thats from the manual. also check your settings in the computer verify greyscale is not selected. also. Re-calibrate anyway To calibrate the printer from the HP Color LaserJet 2500 Toolbox 1 Open the HP Color LaserJet 2500 Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 2500 Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 2500, and choose the HP Color LaserJet 2500 Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Color Calibration. Then try a test page. if all else fails Try this The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state.
Aug 27, 2010 | HP LaserJet 2500 Printer
My printer gets stuck on initializing...or calibrating. I have unplugged, rebooted and have gotten it to say "ready" but still will not print.
After you power on the printer, does it ALWAYS do calibration, and if so, does the calibration cycle complete or just goes on and on?
From your description, it sounds like the printer will come to the READY ... eventually after calibration. That's a good sign. The fact that it does not print could be other factors.
1. first, get a high speed parallel cable and hook the printer directly up to your computer. Be sure your commnications are good.
1a. if you only have ethernet connection to the printer, then you'll need to print out the information page so that you can find the IP address of the printer. If the printer's IP address shows all zeros, then the IP address for the printer's jet direct card has not been defined. Instead of going on about how to install a new port, drivers, etc. please tell me where you're at.
Jan 06, 2010 | HP LaserJet 4600dn Color Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
Unable to print a 4X 6 label
asslam aleekum wr wb
mere pass zebra printer hina but us mian ak problem ya arha hian k us k print out blank arhha hian why?
plz mujhe batey
Apr 22, 2009 | Zebra Z4Mplus Label Printer
Epson Aculaser C1100 Printer Logo
153 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
