Question about Insignia Televison & Video
Can I attach outside speakers to my tv - Insignia Televison & Video
    Problem Solver:
  • 12 Answers
You can if your model supports the outside speakers. Check the user manual. Normally TVs do not support external speakers but they have outputs that would allow you to connect them to external amplifiers or surround systems. Again, all this information should be in your user manual with pictures and detailed explanation of how and where to plug the cables.
Posted on Sep 06, 2009
Can I add speakers to my tv?
Another favourable option is to add BlueTooth speakers that can make your speaker placement wireless and easier without running cables behind furniture, etc. You would need a Bluetooth adapter either pluggable into your TV or externally from cable plugs. It helps that your TV has built-in Bluetooth or Wifi to make this option possible.
Feb 02, 2015 | Panasonic Televison & Video
Only one speaker works, then later the rest works. What do I need to do
Are the speakers external, outside away from the computer? If yes, either a loose connection point where the wire attaches to a terminal or a internal break of the copper wire under the insulation of the wire. Replace jack and wires with new ones and/or find loose wire and tighten or solder depending on how it is attached.
Jun 05, 2014 | Audio Players & Recorders
Sanyo TV speakers are going out
The speakers in these TVs are their weakness. More over you may not get the original speakers easily. Here is the solution if you can do it. It is the rubber ring between the paper cone and the metal body which gets cracked and cause crackled sound. Take a tube of RUBBER solution (the one we use for general purpose sticking) and cover the rubber ring with it properly. Let it dry and put the speakers back. Your speakers will sound as good as original. Good luck. You will not need to use the outside speakers.
Dec 22, 2013 | Sanyo Televison & Video
I cant get my emerson led tv to accept any form of sorround sound
If there are RCA audio output connectors on the rear of your Emerson TV, they should direct your TV audio to an external amplifier to which your speakers are attached. You don't mention this arrangement in your description
Feb 21, 2013 | Emerson 32-inch 720p LED TV Refurbished
Where do you hook up outside speakers
'Outside' is not a choice on the unit.
If you want to drive a separate amplifier with speakers somewhere you could replace the Main Channel Pre-Out jumpers with an RCA-Y-adapter and slave the second amp and speakers to this unit's volume controls; or you could attach a second amplifier to either TAPE REC OUT pair and the external amp and speakers would have independent control of volume locally.
Jul 03, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
Can you replace the speakers in this TV. mine are making static noices
Yes you can.
Speakers are probably good unless they were subjected to the elements(outside TV's do get damaged sometimes from being outside on patio ,etc.
May 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Speakers are not working
some flat screen tvfs in the menu have a selection to turn on or off the tv speakers, my Sony has it in the sound menu it say speaker selection, and the options are TV or Outside Speakers, check for this if they have been fine right along
Mar 20, 2009 | Televison & Video
Mintek Fix
Mike
No problem. What I was suggesting you could do with the speakers is to splice the positive (it should be red or white) speaker wire to the hot part another separate RCA (I used the side input) jack and the ground to the jack's ground sleeve (the outer part). So the process is similar to what you're already doing with the component RCAs and wires. Once this is done you can hook a receiver up to the built in speakers in the TV with no hassle. The speakers will not be powered, however, so you can't just hook the audio output from your cable box to the TV. All this process allows you to do is hook a powered amp or receiver to the speakers.
What I meant by saying to make sure there are no grounds was to double check and make sure each bit solder did not bridge over to another strand of metal or the metal chassis of the TV and cause a short or a ground.
Anything else, just let me know.
Ryan
Mar 11, 2008 | Mintek DTV-263 26 in. LCD Television
Televison & Video Logo
742 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
