HP LaserJet 4 Plus prints only from upper tray not
After I had asked Word Perfect X 3 by Format to use Labels which printed them fine, but after I did that the Hewlett Packard LaserJet 4 Plus printer will print only from upper tray and not lower tray. So instead of 81/2 by 11 printing in lower tray, the display demands that I Feed paper into the upper tray.
checkitright
  • 1362 Answers
SOURCE: Manual Feed
The manual feed door is on the front push and it should release the door, A4 is for Europe, although it will make the copy it will leave  a wide margin on the right. go to hte menu and change the setting to letter.
Posted on Oct 11, 2007
checkitright
  • 1362 Answers
SOURCE: paper jam
Try this
http://www.fixyourownprinter.com/forums/laser/10856#1
Posted on Oct 19, 2007
ginko
  • 19396 Answers
SOURCE: Hewlett Packard Deskjet 840C printer driver
You can find the drivers at : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=59868&lc=en&cc=us&dlc=en&lang=en&cc=us
cheers
Posted on Feb 14, 2008
mattozan
  • 555 Answers
SOURCE: Hewlett Packard LaserJet 4
Click on the link I provided.
Posted on Jul 12, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
I have the HP LaserJet P2014 printer. When I
Tray 1 (MP Tray) paper size and paper type needs to be set to either envelope or labels.
Jun 10, 2010 | HP LaserJet P2014 Printer
Problem with printing from Tray 1
It can be set from more then one place. In MS Word you would go into the tools setting then choose the envelope drop down, select labels and in the options for the label you choose the format as an Avery Equivalent. That is where you can tell MS Word which tray to pull from. Also in the printer properties, under advanced options you can designate what type of paper is in each tray. Good Luck
Jul 23, 2009 | HP LaserJet 4600dn Color Printer
HP Laserjet 4 plus printer
use the m/p tray.configure printer to print any size.
Jun 25, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
52 people viewed this question
k24674
jasbo
jasbo
