Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Start blades engine stops
Engine runs ok till you start blades engine stops
  • 143 Answers
This could be a faulty grassbox switch, or the box is not closing right. Or it might be the blade
safety switch. Check the wires going to the switches, they could be stripped and earthing.
Stephen
Posted on Sep 06, 2009
Johnson 115
find the bottom carb , see where the linkage from the remote cable moves the lever on the side of the engine then disconnect the cable from the remotes ! on the bottom carb there should be a screw to adjust the tickover where the linkage meets the carb linkage , turn it in 2 turns then with water attatched to water intake on gearbox turned on start the engine , it mite be slightly high or low pending ! set at 900rpm , rev engine several times back to tickover and if ok then refit throttle cable , cable should be pushing lever against its stop and then when you select forward gear it shouldnt move till you throttle up ! when in water start engine and select forward gear and tickover should be 7 to 800rpm and idle ok if not adjust till ok !
Aug 12, 2014 | Boating
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Car will run ok for about an hour, then gradually start slowing down till stops. after it sit for awhile it usually starts up and run ok until it has another episode
SOUND LIKE ENGINE GETTING TOO HOT.CHECK THE COOLANT AND THE FAN CLUTCH.IF FAN CLUTCH HAS RESISTANCE WHEN HOT ITS GOOD.IF FAN FREE WHEELS WHEN HOT REPLACE IT.IF FAN CLUTCH GOOD THE THERMOSTAT FAULTY.RADIATOR CORES SLIGHTLY STOPPED UP. CHECK RADIATOR GRILLE MAKE SURE ITS NOT STOPPED UP WITH DEBRIS.
Jul 16, 2010 | 2002 Kia Sportage
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna rider 155 won't start
try checking the ignition switch for any damage and replace if necessary
Nov 25, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
