Question about Biostar U8668 Motherboard
My several year old PC will not. Display powers
My several year old PC will not. Display powers on shows press to enter setup on left ad
U8668 Bios vC01 on the right will not get past this step.
I cannot enter setup nor boot off of a CD. replaced the coin battery and did not change. I suspect bios may be corrupt, but not sure how to resolve
  • 1 more comment
  • mgb1000 Sep 06, 2009
    I think it is setup that way, however, it did not even let me get that far, or get into the setup to even check. Basically it locks up at the initial screen that says press to enter setup on left and on right lists U8668 Bios vC01.
    when i press it says "entering setup...." but never goes past that screen. Seems like the bios may be corrupt. I tried to clear the CMOS by changing the jumper settings and returning to normal like in manual, but exactly same issue remains.
  • mgb1000 Sep 07, 2009
    Not sure why it worked but it did, thanks
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    When trying to boot from the CD did you set the boot schedual to boot from the CD drive?
    President:
  • 1,564 Answers
I just went through this thursday with a Dell inspiron. I was in the middle of a system restore and it just shut down before it even had a chance to begin the restore. I unplugged it and removed the battery the harddrive and the processor heat sink. I cleaned under the heat sing on top of the processor and the bottom of the sink itself. I reassembled the unit and it came back to life. Give it a shot. Try the battery and unplugging a couple extra times if necessary.
Posted on Sep 07, 2009
Testimonial: "Back up and running, thanks"
  • 31 Answers
Maybe u shud check ur battery with some "battery analyzer software" to know if ur battery is faulty or not
My hp 17 inch m7 k211 dx will not turn on the power port light blinks 3 times. Help?
HP ENVY m7-k211dx Notebook PC?
those are called BIOS blink code errors.
take the battery out yet and try, batteries love to dye and short.
run on line AC power only that cure it?
only 1 year old , (or less) 1 is max. Aug 1015 RTM
the books on it are here.
https://support.hp.com/us-en/product/hp-envy-m7-k200-notebook-pc-series/7527539/model/7734388/manuals
with battery out, will the display even show BIOS messeages
see page 84 in the manual.
see this, ? quote:
To start Setup Utility (BIOS), follow these steps:
1.
Turn on or restart the computer, and then press
esc while the "Press the ESC key for Startup Menu"
message is displayed at the bottom of the screen.
2. Press f10 to enter Setup Utility (BIOS)
page 86 shows how to run BIOS base line Diagnostics.
that be next
page 4 in the service manual tells you the power light blink rules.
the lightening bolt LED binks , means no line power, and battery is now dead. is the power pack missing>? unpluged.
try a direct on connection to wall AC power known good?
the same light blinks i SLEEP mode.,
here is HP;s offical blinking (LED) lamp codes and cures.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01732674
Apr 04, 2017 | HP Computers & Internet
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Remove hdd password
You can change it but not 'remove' it. Simplest is to use '00000' as the default password.
Instructions
1 Shut down your computer.
2 Press the power button on your computer. While it is booting, press F2 repeatedly (do not just hold it down) until you arrive at a system screen showing a series of
options. This screen is called the BIOS Setup.
How to change the password on a Dell computer hard drive
Password Vault
Secure, centralized password vault for enterprises. Try now. manageengine.com/PasswordManagerPro
3 Use the down arrow key on your keyboard to scroll down to "Security" in the left-hand column.
4 Arrow right to display a sub-menu under Security in the left-hand column.
5 Arrow down to "Internal HD PW" in the left-hand column. (That stands for Internal Hard Drive Password.)
6 Delete the old password (if any) and, in the same box, enter a new password of at least four characters in length in the main screen at right.
7 Write the password down and keep it in a safe place.
8 Hit Enter.
9 Hit the Escape button on your keyboard to exit the Internal HD PW menu, then hit Escape again to proceed to the Exit screen of the BIOS Setup.
10 Arrow right to save the changes you made to the password, then hit Enter on your keyboard to exit the BIOS Setup.
11 Restart your computer and use the password you created in the BIOS Setup to gain access to your hard drive.
Apr 17, 2014 | Dell Dimension Computers & Internet
Hewlett Packard AllInOne 3101125F When I power on I get no video
these PC are odd ducks, id never buy one, due to there ODD construction, but people do. and fixing it is not easy,
but there you have it.
try a new power pack? yet.
try to find and external VGA jack and use and external screen there?
try to get in to BIOS YET< does it work ? screen work like that.
the goal now must be get BIOS working first, the booting then windoz.
see?
the correct name is
HP TouchSmart 310-1125f Desktop Computer its more of a laptop stuffed in a Desktop screen. really
6 years old.
after adding the Hypen to the p/n HP shows the product support.
310-1125f
I only have questions, after all I cant run it and watch it.
1: does the fan run inside.
2: does BIOS work per the manual.
3: can you hear the hard disk spin
4: does the screen ever show text words, like it did when it worked
at power on, like" press ESC key to setup Bios" does it.
if BIOS is dead, there is NO POWER to the MOBO.
work power.
this PC has no VGA port, on the rear, so testing any PC lacking this key PORT (or DVI or HDMI) make testing it HARD.
the power jack has an LED on the MOBO that glows. does it?
Id say if the BIOS screen is DEAD the power is gone.
can be power pack or far far worse, (why not get it fixed? by a TECH)
https://support.hp.com/us-en/product/hp-g56-100-notebook-pc-series/4247525/model/4332736/manuals
May 27, 2017 | HEWLETT-PACKARD Hewlett Packard AllInOne...
How to enter bios setup to toshiba dynabook satellite 1850
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
Aug 14, 2011 | Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
How do i access bio's on a u8668-d mainboard.. i don't know the key to press
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and chang the first boot device to your hard drive)
hope this helps
Dec 12, 2010 | Biostar U8668D (802700113338) Motherboard
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Biostar u8668 grand does not power up when agp
Good Day sir, try to check the CMOS/BIOS setup, and go look for Initial Display First, there are several options, Onboard / AGP / PCI. OR, after you remove your AGP, clear the CMOS/BIOS setup. find the jumper wire near the battery this sets your motherboard to factory setup and uses the onboard VGA. test the pc without the AGP.
Oct 18, 2009 | Biostar U8668 Motherboard
Computer won't boot or won't even enter setup
Try disconnecting all peripherals then boot up, except for those you need, i.e. video card, keyboard... If that doesnt work you may need a BIOS update... Refer to the picture below to find your BIOS code, the four numbers represent the date which you must use to find out if you need an update...
Apr 03, 2009 | Biostar U8668D (802700113338) Motherboard
Biostar U8668 Motherboard Logo
73 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
