My philips televison doesnt turn on Previously I would just unplug it and plug it back on and would turn on I believe that its the on/off switch that isnt working properly. The TV works it just cant be turned on and off
    Scholar:
  • 146 Answers
You should at least try turning it on/off using a remote if you can't turn it on/off on the TV keyboard. Pulling the the plug on it and turning it on by plugging into the wall isn't a good thing to do, you will eventually burn something out in your power supply or elsewhere due to the harsh transient currents you are subjecting your electronic components to. Your power supply may have a relay in it that delays activationg some components until others are energized and you are bypassing all that with your method.
Posted on Sep 22, 2009
I have a 50pf7321d 50"
Oh. It's Great. Never show it to anybody!!!!!
Jun 29, 2017 | Philips 50PF7321D 50 in. Plasma HDTV
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
My philips televison doesnt turn on Previously I would just unplug it and plug it back on and would turn on I believe that its the on/off switch that isnt working properly. The TV works it just cant be...
try this before you toss it...recently my magnavox 37" had been takign upwards to an hour to turn on. this past tuesday i check these threads to determine the problem. like many have said, its probably the capacitor, which it was n my case. basically i took everything apart and the bad (2) capacitors were obvious. one was oozing the electrolytic fluid and the top of the other started to 'dome' on the cap. i then went to a local electronics store (not radio shack, parts are too specific)... $3 for the (2) capacitors and a $20 solder iron. then you just de-solder the bad caps' and replace. i took the approach that - "what's the worse that could happen, the tv already didnt work?" well i just completed teh fix, it took about 3 hours and saved me nearly $300 that i didn't have. you can't be without your flatscreen at the beginning of football season!!!
gook luck
Sep 06, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philip DCP750/37 turn black and white
I have had this problem all you do it wobble the screen back and forth until you find the right spot. if that doesnt work. unplug it from the charger assuming it is plugged in. If THAT doesnt work, believe me a little "thwap" on the back will.
Jul 14, 2008 | Philips DCP750
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
