Question about Denon AVR588 Receiver
My denon avr589 does not stay on the red light blinks rapidly
I recntly connected my receiver to my bose acutimass 6 system. it played well at first and then i tried to turn my system on and it cut on with thhe green power light blinking and then shut off with the red power lighht blinking rapidly. does anyone have any solutions to this problem
I have the AVR588 7.1 Surround A few models down from the on mentioned here. Same problem, turn it on then after warm up of a minute or so it shuts down and the standby red light flashes. It has the same part failure. KIA7915PI. Ive ordered 4 so I have backups since this seams to be a high failure part. I tried crossing the part to a higher quality part like NTE but I cant find one. My searches on the net I did find many have the same problem but noting on resolving it. The way I found the problem is I associated it as a termal issue so I got a can of freeze it at an electronic supply store and cooled several components one at a time cooling it to see if I could keep the unit on longer. Low and behold as long as I kept the KIA7915PI froze it would stay on. Im still waiting for the parts but to get by I have removed the transistor and soldered three long wires to the pc board in place where the transistor was and the part soldered to the other end. This is to extend the part out so that I can keep it cool in a glass of Ice. I dont recommend anyone doing this if your not familiar with electronics. I was careful soldering the leads of the transistor to the wires not to cross them and make sure not to emerge the leads of the transistor into the water as the ice melts. Crazy but it works for now. As I wait for the part i can kick back and watch some movies with some rum on the rocks as my receiver enjoys its 15v regulator too "on the rocks". LOL
Posted on Jan 23, 2010
The KIA7915 is not a transistor, it is a negative 15V regulator. The 7900 series, and the positive version the 7800 series, are commonly available parts. If you search for 7915 without the KIA, you will find many sources to buy them from. One place that is good for electronic components is Mouser.com
Posted on May 14, 2010
    President:
  • 1,126 Answers
Denon avr-1513 shutting off and blinking red light
Sounds like you could have a bad speaker connection. Try disconnecting the speakers and see if it stays on. If so, connect one at at a time until it goes off to determine which one.
Jan 20, 2013 | Denon 5.1 Channel Receiver 1080p AVR-1513
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Bose 3-2-1 system subwoofer connect to denon avr
The subwoofer is not designed to be connected to a non-Bose amplifier.
Jun 07, 2012 | Bose Audio Players & Recorders
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Dec 05, 2009 | Audio Players & Recorders
Power light blinks off and on Red
* The speaker terminals are shorted -- Disconnect speakers one at a time and try again.
* Ventilation of the unit is inadequate
* Has been running at too high a volume with inadequate cooling
Go here, register and get the manual for free....
http://www.fixya.com
Search for Denon-AVR-485S
May 04, 2009 | Denon AVR-485 Receiver
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Denon AVR588 Receiver Logo
1,937 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
