Ive just got my computer back after being repaired and my cd writer drawer wont open but it opened when i put it in to be repaired can youi tell me what is wrong
    President:
  • 1,996 Answers
It sounds like the technician forgot to reconnect the data cable or power supply to the cd drive. That's one possibility, anyway.
Take a look in the device manager or the bios setup and see if that drive is being detected. If not, you could open the side of a desktop and, after grounding yourself out against the metal of the case, see if the cd drive power cable and data cable are connected correctly. Perhaps remove and reinsert it. Check both ends of the data cable. If it's a laptop, you could take a look at the support site for your system and see if they have a service manual available for download that will walk you though the steps.
Or take it back where they "fixed" it. They should be able to patch it up pretty quickly while you wait...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 06, 2009
How do I fix my computer CD writer Drawer to make it open.I banged it with my knee when it was open,I pushed it closed and does not open any longer.Its the HP 583 Pavillian model,not new but works wel
Many times you will see a small hole next to drawer, try something thin lika a paperclip & give a gentle poke inside. Feel for a button type spring response.
Oct 15, 2014 | Computers & Internet
A cd broke inside my dvd writer while using it, and now it wont eject
on the left side of the front pannel just under the drawer you will see a pinhole.turn your cd unit upside down and insert a straightened paperclip in the hole keeping it straight as possible,the drawer should open enough to allow you to grip it .
if no luck you will have to remove the case top and manually remove the disc..
hope this helps.....Len..
Jan 13, 2014 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
CD-ROM drawer deos not open
There could be a hardware issue or something stuck in there.
In front of the CD drive you will see a pin hole as shown in the image below.
Insert a pin in the hole and and press it. The tray will come a little ahead, you can pull it out. See if there is something getting stuck or any cd inside it. Close it and try to open it with the button. If it wont work it is a hardware issue and need a replacement or repair.
Note: You can take out the tray with the help of the pin, even if the PC is turned off.
Regards,
Shrey
May 30, 2011 | Computers & Internet
6mmy cd-rom /dvd burner while burning a cd the cd got stuck and i had to jopen the computer to get it out, but when i put it back there is a cord came loose with p4 on it and i don't know where it goes,...
When you press the OPEN/CLOSE button on the CD-device, does the drawer open/close, i.e., is it getting electrical power to the motor that moves the tray?
You say "won't burn" -- will it READ an existing CD disk?
If so, then spend $40 to buy a replacement CD/DVD reader/writer.
Look for a WHITE coloured rectangle near the CPU that will fit that 'P4' cable from the power-supply.
Or, look at the "back' of the CD-device.
There should be two cables: one for "data" and one for "power" that connect to the CD-device.
Sep 27, 2010 | Dell Computers & Internet
My CD writer will not open to insert the CD. What
Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
Mar 08, 2010 | BUSlink (RW4848FM) CD-RW Burner
I purchased a plextor px-870a dvd/cd writer to replace the cd writer in our computor it is a dell with a dvd player in the top slot and a cd writer in the next slot down but the cd writer stoped working so...
On the back of a CD-writer or a DVD-writer is a small grid (2 rows) of gold pins.
Each vertical set of pins is labelled: MA(ster), SL(ave), and C(able)S(elect).
Be sure that one drive has a small jumper between the MA pins,
and the other drive has a small jumper between the SL pins.
Was there any software on CD-ROM that came with the DVD-writer,
e.g., software to play DVDs, and software to write CDs and DVDs?
To "play" a DVD, you'll need that software.
To "play" a music CD, Windows Media Player will suffice.
Nov 23, 2009 | Computers & Internet
Acer 9300 overheating problem
it doesn't sound like you are too computer savy...so I suggest you find another computer shop to fix both problems for you
Mar 15, 2009 | Acer Aspire 9300 Notebook
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Internal cd writer
yes, you will need to remove and open the rom up and re align the door to gear.
Nov 01, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
