Question about Coleman Heating & Cooling
The error light indicates there is a problem with the limit switch but can not find it.
  • bjskorcz Sep 06, 2009
    no the unit will not turn on the only operation is the fan and heater but no cool
    President:
  • 1,564 Answers
Can you hear a clicking while raising or lowering the temperature control?
Posted on Sep 06, 2009
Keeps throwing up trouble codes p1506,p1151,p0302,p0171
Definition of Diagnostic Trouble Code P1506 Audi: Closed Throttle Position Switch Does Not Open/Short to Ground BMW: Idle-Speed Control Valve Opening Solenoid Control Circuit Signal High Ford: Idle Air Control Overspeed Error (see P0507) Jaguar: Idle Air Control System RPM Lower Than Expected - B Bank Kia: IAC Valve Opening Coil Voltage High Lincoln: Idle Air Control Overspeed Error (see P0507) Mazda: Idle Air Control Overspeed Error Mercury: Idle Air Control Overspeed Error (see P0507) Porsche: Throttle Jacking Unit Lower Mechanical Stop, Signal Implausible Volkswagen: Closed Throttle Position Switch Does Not Open/Short to Ground Volvo: IAC Valve Opening Signal
Definition of Diagnostic Trouble Code P1151 Audi: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Jaguar: Lack of H02S-21 switch, sensor indicates lean Land Rover: Lambda control limit bank 2.Implausible signal/condition Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Subaru: HO2S-12 Heater Circuit High Input Toyota: Coolant Path Clog Up for Coolant Heat Storage System Volkswagen: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
Definition of Diagnostic Trouble Code P0302 Category: Powertrain Definition: Cylinder 2 Misfire DetectedNote: This definition of P0302 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0171 Category: Powertrain Definition: System Too Lean Bank 1Note: This definition of P0171 is applied to all manufacturers
Jun 17, 2015 | Cars & Trucks
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Goodman dependable 92,7years old. Furnace works sometimes. Checked out by qualified technican. no problem found. Constant checks shows troubleshooting light blinks three (3) times. Help please. 3...
This indicates a open limit switch on the furnace, the heat exchanger is getting to hot therefore the limit switch is opening and not allowing the furnace to work properly. Did the techinician check the limit switch on the unit?
Dec 30, 2010 | Goodman GMS90703BXA Heater
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Dryer blows cold air, drum rotates, light inside does not light up & it is not heating up
remove the back and check the low side limit switch on the heating element housing! as well as look for lose contacts on the limit switches which are a good indication there bad
Jan 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
H1 error code; what does that indicate?
H1 indicates the high limit switch has been tripped. Usually, only a temperature of 114 degrees will trip it or the switch itself may be bad. Depending on your setup, if you just have a normal mechanical time clock, you should have a fireman's switch wired in that will shut the heater off 15 minutes before the pump shuts off.
This can also be caused by a bad or improperly adjusted pressure switch. This can be tricky especially if the heater is installed below the pool water level. If you know that the heater has not tried to fire when the pump is off, then I would suspect the high limit switch has failed and needs replaced.
Oct 28, 2009 | Pentair 200k Minimax Ch Ng Mv Heater
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Heating & Cooling Logo
13 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
