Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Brewed coffee will not come out
We have had our Saeco Vienna Digital for almost 5 years. Pretty good compared to most of the reviews I have read for this product. We have had to send "our baby" in for repair twice. One time it was a ring that needed to be replaced, I believe it cost us about $115.00, and the second time it was the computer which put us back $250.00 We love our machine so much and are so dependent on it, we just wanted it fixed. It's been working fine for almost the past 2 years now, I keep it immaculately clean. The past couple of days, our water tank kept on leaking. Today, when we went to make coffee, the coffee got ground, you hear the water prebrewing, but NO COFFEE COMES OUT! I am having serious withdrawal right about now. I want it fixed! So I cleaned all the components as usual, tested it a few times and nothing. Any assistance is really appreciated. Thank you for your time!
Tina
  • madrkulec Jan 17, 2009
    have the same thing happening, my friend says this also happened to her.
    they cleaned out the water line and then 2 years later needed a new water pump
    all can be bought on line and can do it yourself
  • NMA97 Feb 03, 2009
    THE COFFEE DOES NOT DISPENSE FROM THE MACHINE.
  • 74 Answers
First when the watertank is leaking its usally not the tank itself but the gasket were you but the watertank down in.
About that the coffe wont come out i dont agree that you have to clean the coffegrinder.
First i would trie and set the grinder to more coarse grinding and see if that helps.
second i would trie and clean the filter on the brewing unit. take it off and clean it on the back side. remember not to use the tool you get with the machine to fasten it again as that will probebly brake the brewing unit.
Posted on Jul 11, 2008
  • 40 Answers
Two things you point out. One is water tank leaking- where is it leaking? Is it cracked?
The other problem you point out is that coffee is not coming out but do get water- which could be that the grinder needs to be cleaned (internally) by an authorized SAECO Service Center .
Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
I have a Saeco Vienna Digital expresso machine. I am wondering what the settings should be for the 2 knobs in the bean hopper. One knob has +- settings and the other reads 0-18.
Hi
A good setting would be 8 for the big knob and half way from the neutral to the + side of the small knob. Never all the way to the + as you could get an overcharge and damage the brew drive gears.
Nov 02, 2010 | Saeco Vienna Digital Coffee Maker,...
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
Sep 21, 2008 | Saeco Vienna Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
91 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
