Question about LG Xenon GR500 Cell Phone
Nokia shuts down
My nokia shuts down as soon as I make a cal. THe battery is charged
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
N5010 battery issue
i can advise u few steps to make the battery life better
1. drain battery completely then charge it
2. run a battery self test (charge and discharge battery 3 times)
3. switch off wifi and bluetooth when not in use
4. scan pc weekly to check for virus
5. use power save option
6. shut down when not in use or atleast put to hibernate
Feb 13, 2012 | Nokia N Computers & Internet
Nokia 5230 battary heat problem
watch up battery carefully if its leaking get a new immediately otherwise nothing will happen because these s60 os demands great energy so dont worry
May 04, 2011 | Nokia 5230 Cell Phone
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Nokia E61i will not shut down! Nothing happens
Remove ur battery and re fix it, after tht restart ur mobile phone
Mar 25, 2010 | Nokia E61i Cellular Phone
Hi have had my nokia 6280 for 2 and a half years now...replacing it soon but need it to function for another two months! problem is my battery started taking forever to charge and then stopped charging...
hi thanks for using fixya!!
On this kind of error, even if you had to change the battery or even the charger, perhaps the power supply internally is already damaged. Charging for more than 2 hours is a sign of something is not good and after that still shutting down. I recommend that you bring your phone to a Nokia Care Center or any service center to further check the hardware parts.
Regards.
May 15, 2009 | Nokia 6280 Cellular Phone
LG Xenon GR500 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
