Question about Dehumidifiers
The red full bucket light is flashing on zenith dehumidifier zd30
My zenith dehumidifier zd30 won't cycle on. The red full bucket light is flashing, but the bucket is empty.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
SOURCE: My 1 yr old Zenith ZD30 dehumidifier just stopped
The Zenith ZD30 is made by LG as many other brands are also. There is a fuse located on the control board. That may have blown. I have also had 3 LG units come into my shop with bad control boards. If the fuse is ok. Measure the ohms at the power plug L1 to Neutral, with the unit unplugged. It should read around 430 ohms. The ones with bad boards read real high. Hope this helps.
Rasske's Renewed Appliances
Posted on Aug 19, 2010
SOURCE: Zenith ZD30 dehumidifier - 1 1/2 years old stopped
I have a Zenith ZD30 dehumidifier and it would shut down after a few minutes of running when I turned the knob to off and then clockwise it would start running again. I have just tried unplugging the 2 wires going to the POT and the unit is running fine. Then problem is that it will keep running now until the bucket fills
Posted on Oct 07, 2010
Zenith zd300yo display flashes ''01''and bucket full flashes
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 13, 2011 | Dehumidifiers
Bucket full light flashes, humidity setting won't change - only says 01
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
My ZD30 Zenith dehumidifier..starts, after 10, 15 seconds the full indicator light starts blinking and it stops running!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Aug 30, 2010 | Dehumidifiers
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
What causes a dehumidifier to just stop running or operates very inefficiently? The filter is clean.. Zenith ZD30
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 06, 2010 | Dehumidifiers
Red light is flashing on my Zenith dehumidifier every 7 seconds or so. Bucket is empty. what should i do to get it running again?
take out bucket and locate bucket full switch, depress it, if unit works you will need to add shim to bucket to hold it in.
Dec 31, 2009 | Dehumidifiers
My 1 yr old Zenith ZD30 dehumidifier just stopped working all together. The bucket is empty and I checked the to be sure that a circuit didnt trip. Any suggestions as to what it can be?
Oct 20, 2009 | Dehumidifiers
Dehumidifiers Logo
502 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
