Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop keeps shutting down for no reason leaving blank screen
    Problem Solver:
  • 12 Answers
If your laptop cuts the power off (shuts down) from time to time that may be overheating problem. Dust is blocking the air outlets on the fan and processor cannot be cooled down properly. Thermal protection shuts your laptop down when it reaches some certain temperature. Most likely you will hear your fan spinning full speed before the shut down and the bottom of the laptop is hot.
Best solution is to take it apart, remove the fan and the heatsink, clean them thoroughly, apply new thermal compound and assemble the laptop. Easy solution (though not the best one)is to buy compressed air can and blow it through the vents of the laptop. It will help for some time but occasionally it will start again.
Posted on Sep 06, 2009
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
How do I fix a blank screen problem with my HP Pavilion dv7 laptop?
1) Connect an external monitor to the monitor port of your laptop.
2) Shut down your system from the START menu.
3) Take out the battery
4) Leave power cord in for 2 minutes...then REMOVE it.
5) Press your on/off button for 45 seconds.
6) Make sure your screen is at greater than 90 degrees
7) Plug in
8) Press your on/off button to power laptop.
if this doesn't work, try taking out the RAM.
Oct 22, 2010 | HP Pavilion dv7-1129wm Notebook
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | Computers & Internet
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
May 17, 2009 | Dell Dimension 3100 PC Desktop
Pc keeps shutting down
hi
do you have the power saving settings to switch laptop off after a certain lenghth of time?is the laptop overheating?are you using it on a soft surface eg deep pile carpet?
Jan 24, 2009 | Acer Aspire 3690-2196 Notebook
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
1,024 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
