Question about Compaq Presario CQ50-215NR Notebook
I have a compaq presario cq50 215-nr. the lcd screen constantly flickers with colored lines going top to bottom. I can work if I press the screen down. I called HP they say that this comes under accidental damage and we will charge you $400 + tax bucks for lcd crack to repair this? Is their a work around because I never dropped it or anything?
    Problem Solver:
  • 11 Answers
I am sorry to tell you that the screen has been damaged and will need to be replaced. There is no work around/solution for a bad screen. Replacement is the only way to go. Sorry.
Posted on Sep 07, 2009
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
My screen has a vertical line red-yellow-green from (top to bottom) that stays there. How to fix it?
I do not know any setting that makes a vertical line red-yellow-green from (top to bottom)
If you can find a monitor to connect to and know how to tell the PC to send a signal to it (ie, on a Dell it is Function F8) you can determine if it is your Video card or your screen that has failed. The Video card is part of the Motherboard and very challenging to replace. The LCD screen however is not as expensive and relitively easy to replace. You can watch YouTube videos on how to. A screen can be found at sites like Amazon and EBay.
http://www.amazon.com/Compaq-Presario-CQ70-120US-SUBSTITUTE-REPLACEMENT/dp/B005788D22
http://www.ebay.com/itm/NEW-COMPAQ-PRESARIO-CQ70-120US-LAPTOP-LCD-SCREEN-17-/200514204266
Aug 20, 2011 | HP Compaq Presario CQ70-120US Laptop
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Compaq presario cq40 lcd monitor is flickering/has colored lines appearing 1" thick at the bottom and at the top.
The first thing to check would be the cable, make sure that they are securely in place. Then maybe reseat your graphics card if your not using on board graphics. Then I would check for updated drivers via the manufacturers website.If none of these work, check the ends of the cable for bent pins, also try another known good cable to see if that is where the fault lies, if none of these work then I am afraid you may have a faulty monitor, try on another screen if you have one available.
May 05, 2011 | Computers & Internet
Sceptre 47inch flatscreen lcd has purple line vertical 2 inches from left through entire screen and all channels
is it solid lines or do they flicker, come and then go based on what colors are on the screen. Also does the interlace spread the horizontal line from top to bottom and bright colors?
Jun 20, 2010 | Televison & Video
Compaq presario F700. Display screen is garbled and illegable most of the time. Occasionally it will come up perfectly normal and clear but majority of time its a bunch of multi colored lines flickering....
Since the problem you describe is intermittent I would first suspect a loose or shorted electrical connection. To check this you will need to take the computer apart. Step by step photos of this procedure are at http://www.insidemylaptop.com/disassemble-compaq-presario-f700-notebook/ .
Once you have access to the lcd cable you can check its connection and the condition of the cable itself. If the connection is secure and the cable looks good you probably have a bad lcd.
Nov 28, 2009 | HP Compaq Presario F500 F700 and G6000...
The screen on my laptop flickers colors and there are lines running through through middle red blue green ect.. it does work on an external monitor tho could this be the lcd inverter
Lines on the screen means the LCD is bad and needs to be replaced. The inverter just makes sure the lcd turns on. That wouldn't cause lines on the screen.
Nov 28, 2009 | Compaq Presario R3000 Notebook
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
Compaq Presario CQ50-215NR Notebook Logo
1,087 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
