Question about Weber Genesis Silver A Grill
Will not heat up past 375 - Weber Genesis Silver A Grill
    President:
  • 497 Answers
Propane or electric? Are you going by the thermometer on the grill or using a external one?
Posted on Sep 06, 2009
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Oven problem
What is the model number?
Apr 29, 2013 | Kitchen Ranges
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem...
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Feb 03, 2010 | Kitchen Appliances - Others
Oven over heating , from set temp of 375 to over, third time the
Have you changed the oven sensor. If you have the problem is with the main oven control. Let's hope sensor for cost.
Feb 01, 2010 | Ovens
Tappan oven is heating up way past where the temperature is set. I even set it to 200 degrees. It goes up back 375 and still kicks in the heat up!
Sounds like a defective thermostat, look inside the oven for a sensor. It should hang from the oven top or high up on either side attached to a little clip. Looks like a metal thermometer.  If it is missing or damaged that would explain the problem and must be replaced.
Jan 31, 2010 | Tappan TGF657 Gas Kitchen Range
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
Apr 22, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Do not know how to use
Oil darkens with use the oil food molecules burn when subjected to high prolonged heat.
When frying foods such as fish or chicken use the oil once.
Do not filter oil over to reuse. Storing the oil in the refrigerator may extend the life of the oil, this should not be done ever. This process of chilling the oil and then burning the oil to room temperature causes excessive splattering furing the heat up.
Storing the covered oil in a cool dark place, for up to three months. ( remember to check oil when you use for color, smell, or excessive foaming. Throw out if there is signs of all the above.
This unit has a warranty for one year from the day of purchase.
Cooking:
When starting let unit reheat 7-10 minutes. This will get the heat to desired temperature. Re4ady light will cycle on/off during frying as temperature fluctuates due to food load.
Types of foods cooking: temperatures and time of cooking
Chicken strips 375 F. 5-8 minutes
Chicken pieces, bone-in 375 F. 15-20 minutes
Fish, battered 340 F. 8-10 minutes
French fries, frozen 375F. 3-5 minutes
F375F. 3-5 minutes
Onion rings 375 F. 3-5 minutes
Shrimp, breaded 375 F. 2-5 minutes
When frying frozen food if iced rub off lose as this can make the temperature of oil cool down. Pre-cooked frozen food cooks faster and does not come out oily.
I cannot wait to start cooking in mine as I got it for a christmas gift. Great recipes in the owners manual:
Apples fritters yum yum,beer batter for fish or chicken, deep fried chicken , chicken Kiev, quick doughnut made from biscuits, add topping of ground cinnamon and suger.
Dec 13, 2008 | Rival CZF625 Deep Fryer
Oven shutting off
To start with, F-1 is Failed Start.. When U hear the Beaping, U need to Push STOP, that will keep the Broiler from coming on.. Then put it back on the settings that you want. My Stove used to do the same, and it finally stopped doing it.. Hope yours stops...
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
ERD36 Oven over heats
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Sep 11, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Weber Genesis Silver A Grill Logo
124 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
