Question about HP Photosmart 2610 All-In-One InkJet Printer
PH PHTOSMART 2610
I run Windows XP Professional. My printer worker perfectly until I tried to add another printer to my computer. Since that time, my printer will not work!!! I sent a document to print, but nothing happens -- for days....
  • bartman9731 Dec 21, 2007
    un pluged my 2610 to hook up another printer, then hooked it all back up now it will not print from my comp.. copy light stays on
    Novelist:
  • 79 Answers
There might be an issue with the spooler service of your computer , u can download the file from the link and run it , that might help
You can use a tool from Microsoft called cleanspl.exe, available in the Windows 2000, XP or 2003 Resource Kits (http://www.microsoft.com/downloads/details.aspx?FamilyID=9d467a69-57ff-4ae7-96ee-b18c4790cffd&DisplayLang=en). cleanspl.exe from the Windows 2003 Resource Kit tools will work on Windows XP.
Some information about cleanspl.exe:
  • cleanspl.exe does a very good and thorough job of cleaning up the print spooler stuff,
  • When you run cleanspl.exe it will ask you if you want to remove some things that are actually delivered (and installed by default) with Windows. In most cases, you should answer No to the corresponding prompts (you don't want to remove the Standard TCP/IP Port or the BJ Language Monitor).
Note >> when u get the prompt select no on those.
After running it u neeed to reinstall the printer drivers .
Thanks
Posted on May 30, 2008
I have a C4400 phtosmart printer.My orginal HP disc installer is compatible with windows xp. However I am now using windows 7 Ultimate? I cannot carry out the installation. Pl advise.
Hi M. Lee.
You posted printer question under water heaters so questions comes to hardware department instead of 'computers and software.'
Please re-post question under software for best shot a expert in that field.
I am a timer and water heater expert.
Windows 7 has XP mode, but I have no clue how to change windows 7 to XP mode, so please re-post question under software.
Good luck, Geno
May 16, 2011 | Water Heaters
I want to wireless print to my HP 2610 printer through an Airport express router using Windows xp. When I attempt to install the driver I get a message that a printer cannot be detected on the network...
First install the Printer with USB connectivity.
Then insert the printer driver CD again. You will get the Add a Device option this time on the Welcome Screen.
Select it. Now before you continue, just add the exceptions to the firewall list.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01545804
Perform the steps given on the above document to add the exceptions to firewall.
Then Make a right click on My Computer Icon on your desktop.
Go to Hardware Tab. Select Device Mananger.
Go to View Tab on Device manager and select Show Hidden Devices.
Then search for Multifunction Adapter. Uninstall the printer icon under it.
Now click on Add a Device.
Try installing now.
May 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
Printer starts but then gives an error code
Try uninstalling the Printer drivers from the program file and then install the printer drivers from MSconfig.
If you have windows XP or any latest operating system u can try ms config.
Click on start then click on run and type MSCONFIG
select "selective start up" and then install the printer drivers using the cd.Click on add printer and continue the steps.
After installing once again come back to msconfig and select normal startup.
Let me know if the problem still persists
Jeeth
Jun 12, 2009 | HP Photosmart 2610 All-In-One InkJet...
Black ink wont print or prints with blank lines through words
Hi! In your case try to change the printer port in the printer settings. I think the only problem you have is the communication between the printer & your computer. pls check. GOOD LUCK
May 15, 2009 | Microsoft Windows XP Home Edition
Should I risk installing SP 3 for my Windows XP home edition?
It's Perfect runs faster more security and its free i'm running it now
Dec 31, 2008 | Microsoft Windows XP Professional
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Job stuck in cue, won't delete. printer won't print
Have you tried restarting the print spooler?
What exactly is the version of you PC? WINXP, 2000, Vista?
If you are running on a Windows 2000 or Windows XP
1. You just need to click on START > CONTROL PANEL > Administrative Tools then Services
2. Inside Services window scroll down and look for print spooler
3. Click on stop the service and then after at least 5 seconds start the service
4. Restart your computer and check again if the print job is still there.
Jun 17, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Printer /scanner problem
Are you running a space cleanup utility? HP unhelpfully uses the .tmp extension for live files, ensure you're not deleting them. I got "Scan.msi not found" and had to reinstall my AIO software every time until I told WinOptimiser to stop deleting .tmp files (except in the genuine TEMP folders).
Nov 26, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
