Question about Kenmore Elite HE5t Washer
Kenmore elite he5t steam is locked & display says f35. What does that mean?
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
Jan 18, 2015 | Kenmore Washing Machines
Sud appears, followed by F35
Hello & Welcome to FixYa
F35 error means that there is some sort of problem with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore Elite HE5t Washer
Hi After a year of using my Kenmore Elite HE5T washing machine, Model #110 47789701, serial #CSW2733428 I am getting an error F35 and Sub. Could you please let me know how to fix it? Thanks Barb
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kenmore Elite HE5t Washer
Displaying f35 and sud how do i fix
F35 error code means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer is about 2yrs old. I am now consistently getting either "Sud" code or F35. Is there a part for the F35 that needs to be replaced? If yes, could you let me know as well as...
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore Elite 45986 Front Load Washer
F35
Code 35 if a pressure switch problem. If you remove the top panel the switch is located at the back right corner if looking from front to back. It a brown color usually. Check the hose from the tub to the switch and the wire connections if they are ok then replace the switch. Make sure to unplug the machine before removing the top
Jul 08, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
F35 code appears, even after changing the steam chamber.
IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
May 27, 2009 | Kenmore Washing Machines
Kenmore Elite HE5t Washer Logo
484 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
