The compressor fan does not spin and sometimes it spins backwards
Have a York less then 3 years old unit, the fan stopped spinning, and hummed. Took out the capasitor and cleaned the terminals - put it back in and the fan spun back wards - I suspect the capacitor is not functioning properly, and that the fan motor sustained damage.....I also inspected the fan motor unit, and the shaft spins freely......at this point I am ready to replace them both. Now the next question - I have found the motor and capasitor on several sites that support HVAC - what I found was capasitors for 18$ verses the 118$ i am being qouted at stores and most web sites....what's the difference?
  • 3,361 Answers
Your capacitor is definitely the culprit here.
It should be a dual capacitor. Meaning it has 3 terminals on one capacitor. "C" "H" and "F" would be the markings for power in,"C" out to fan "F" and out to compressor "H".
It also has a mfd(microfarad) value on the capacitor as well as a VAC rating of 370 or 440 volts ac. A 440 VAC can be used in place of a 370vac.
The other specs may be something like 40/5 or 35/5 or 40/7.5 etc.
The capacitor replacement should be exact as far as the microfarad rating is concerned.( eg. 40+5).
The money requested through various sites is just that....various. These dual caps may sell around 30-50 dollars for a quality capacitor. If you wish to spend the $118 I will sell you all as many as you would like.
Posted on Sep 06, 2009
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
Fan does not spin
Window unit or outside unit? Start and run caps are large problems,especially after several years operation or a lightning storm. Post more info. A humming sound in a fan or compressor that won't start usually means the capacitor got blown out.. It cost less than $30. (plus service call). LOL
Dec 10, 2010 | Heating & Cooling
On my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
Jul 19, 2009 | Heating & Cooling
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
288 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
