Question about LG GSA-H55N DVD-RAM Burner
Installed by a computer tech he did not leave disc had to reboot puter now does not recognize after markest drive Been about 3 years
    President:
  • 1,996 Answers
Are you running xp?
Doesn't matter. See this post and the links within it to help you. Especially note the instrucitons about the registry filters in the first link and this article. Usually that will do it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 06, 2009
DVD/CD drive won't recognize discs. System says corect driver installed
Is it a disc that someone made on their computer and gave to you or is it one you purchased from the store? Computers sometimes have a hard time reading a disc that someone made and gave to you. Try a disc that you purchased and see if it plays it.
See if you can update the driver in the device manager.
Uninstall the DvD Drive from the device manager, then reboot and let it reconfigure everything. Go the Control Panel and under System find the device manager. Right Click on the dvd drive and select uninstall. Reboot.
Reseat the the disc by unplugging the power cord, remove the battery, then turn the laptop over and remove the screw that holds the dvd drive in place. Pull the drive out, then put it back it.
If you are using Windows Media Player try the VLC player.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Apr 14, 2012 | Computers & Internet
Lexmark 7170 all in one scanner not working - printer and copier is working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If you're scanning documents for editing, make sure that the Lexmark OCR scan software is installed on your computer. The OCR scan software is only available on the installation disc that came with your printer (no downloadable version). If you have the disc, simply insert the disc into your computer hard drive and execute the file.
Dec 22, 2011 | Office Equipment & Supplies
I have an HP Pavilion a6647c desktop computer, running Windows Vista. Only 1.5 years old (bought 3/2009). when we try to turn computer on, IF we get to Windows logon window, it will freeze right...
Hi There,
Your problem has likely only 3 sources.
1. Corrupt Boot Files in Vista
2. Virus
3. Hard Drive locking up.
PLease boot into Safe Mode, download Malwarebytes Free Edition malware remover, stay in Safe Mode and run it there.
If no viruses are found for you to remove, you nedd a Vista Program Disc. Boot from the Disc and use Repair.
If no luck there, return to Safe Mode and use Sytem Restoego back to the earielst point in time in the past when you remember you puter running correctly.
Failing in all these, you likely need a new hard drive and start fresh.
Remember,
DON"T SHOOT THE MESSENGER!
Regards,
Selk
Nov 19, 2010 | HP Computers & Internet
Dell DV051 - message no boot device
Go into your BIOS by pressing F2 and see if the hard drive is being recognized in there. If it is then reset defaults in the BIOS and reboot and see if the computer will boot back into windows. If it doesn't then you'll need the discs to restore the computer back to factory defaults. If the hard drive is not being recognized in the BIOS then make sure the hard drive is hooked up properly. IF it is and its still not being recognized in the BIOS then the hard drive is bad.
At that point then you'll need to replace the hard drive and use your discs to restore the computer back to factory defaults.
Aug 07, 2009 | Dell Inspiron 530 Desktop Computer...
My Computer doesn't recognize my internal dvd drive.
remove dvd drive, remove the dirvers, turn off computer, leave off for about 2 minutes, go to add new hardware, let it search, when it asks you if you installed it say no, it will tell you to do so, , turn off puter, plug dvd drive in, start it, let the puter do it's bootup stuff, if it dosent say it found it, go into control panel, add new hardware, let it go thru the checking phase, if you have driver disk, it should tell you it needs them, make sure all power plugs and comunication cables are tight and connected in right places on mother board, .....hope it helps, might have to do it a couple of times it a tedious thing, you'll get there....good luck...shia
May 03, 2009 | Dell Computers & Internet
System does not recognize CD/DVD Drive
The yellow triangle means there is no driver installed. There is 3 ways to get a driver. In most cases you right click on the hardware in Device Manager and download driver or reboot and Plug n Play should pick up driver automatically. If none of those work then the only option is to load it thru the add/removal in the control panel using the disc that accompanies the softeare.
Apr 01, 2009 | Dell Studio 15 Laptop
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 21, 2008 | Acer Aspire 5100 Notebook
Disc drive will not recognize blank discs.
let's make sure that's a DVD RW disk shall we? check the front and make sure it says DVD RW..if it's DVD R, then it can't write.
Mar 17, 2008 | Gateway 7330GZ Notebook
Hitachi LG GSA-4120B
here's how, you have to oppen that computer, take that cd drive out, dismantle it, and personally clean the lens, duat must have collected on the lens for the long years of not usin it, if you are currently online we'll do the dismantling and cleaning together, contact me e-mail: coolmannybarila@yahoo.com mobile phone: +639152192626.
Aug 27, 2007 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
We have a goodmans g-shot2025tft and have pictures on hard drive, no memory disc used at the time
Forget the disk --always forget the disk for any camera leave it in the box. Connect the camera to the computer via the supplied USB cable. Ensure the camera is powered on and the image upload control is set [see you manual] The computer will see the connection as another drive. A window will cone up asking what you want to do. Select MOVE to a folder- making a new folder and name it and click OK. The Move command will remove the images from the card completely thus leaving ready for your next session. Let Windows Do The Work.
May 15, 2007 | Goodmans G-Shot 2025TFT Digital Camera
LG GSA-H55N DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
