We have a Kenmore washing machine, model 82984120, purchased in 1991 and have never had a problem. We have begun getting a foul smell after we finish washing. When I shake the basket, I can hear a bit of water still swoshing around.
  • r_bisbee Sep 28, 2009
    We did the procedure as directed two times. The odor remained. We then tried a third time but half-filled the washer with hot water and the bleach and let it sit for an hour before draining. That finally did the trick.
    Thanks,
    Richard
    Top Expert:
  • Washing Mach... Master
  • 76,691 Answers
THERE IS ALAWYAS WATER PRESENT IN THE WASHER DRUM, RUN A LOAD OF HOT WATER WITH 3 CUPS OF BLEACH IN IT THIS SHOULD KILL THE MOLD THTAT IS CASUING THE SMELL, USE THE HIGHEST WATER LEVEL SETTING, DO IT TWICE AS NESS.
Posted on Sep 06, 2009
Testimonial: "See my comment below."
What is the foul smell from and how do you fix it?
There is a cleaning solution that needs to be run through the machine, routinely. All of the machines seem to do this....
Mar 09, 2011 | Kenmore HE2 Plus Front Load Washer
The waqshing machine smells inside
All front loader have this problem. Use concentrated lemon juice to clean the boot and then you will have to leave the door ajar just a bit every time you finish washing. Sorry but this the nature of having a front loader. Also using powdered soap products will also almost completly do away with this problem.
Jan 31, 2010 | Kenmore 44921 Front Load Washer
Kenmore front load washer emits foul smell
you can order some cleaner to take care of the smell from WWW.SMELLYWASHER.com
Jan 21, 2010 | Washing Machines
Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Nov 22, 2009 | Kenmore 24902 Top Load Washer
Foul water smell from the washer, occassionally clothes still very damp.
Run a wash cycle without clothes and run with hot water, detergent and a cup of baking soda. Get in the habit of leaving the lid open after each washing session which lets the interior dry out. Make sure the drain water leaves forcefully as this is a timed event--check the drain hose for bends or kinks.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Foul odor after washing - what's happening? should the drain hose go down to the floor, before it goes back up to the house drain?
This is hard to rectify without seeing the machine, but it sounds like you are getting drain smells. Do you have a water trap in your pipe that goes to the drain? if not then install one this will stop the drain smell getting into the house. No the outlet pipe from the washing machine should not need to go to the floor. Other than that you may have a build up of slime in your machine you can by products in the shop for cleaning the machine.
Aug 05, 2009 | Kenmore Washing Machines
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
