Question about Craftsman Saws
I need the rubber tires for a Craftsman 103.24300 3-wheel band saw. Do you know where I may find them? They are 6" in diameter.
  • 2,176 Answers
The part number is 36815 at a price of 9.49 each and you will have to call your local Sears to order them. Let me know if you need more assistance and if I have helped you would you please rate this response accordingly. Thank you
Posted on Sep 07, 2009
Where can I purchase a replacement tire for a Craftsman 7 1/2 inch band saw ? It is for the lower drive wheel and is app. 10 inches in diameter. It is rubber.
I love using both rubber and urethane tires. My old 14" band saw runs for 15 years with rubber tires on it; I changed it when it started cracking with urethane tires that I got from bandsawparts.com
Jun 09, 2014 | Saws
I need the wheel band (tire/gasket) for the performax 9" band saw
I can't find good supplier for 9" band saw tire. Delta makes 9" saw, you might be able to find one with them , Ebay might be selling 9" tire too. I purchase my tires on bandsawparts.com . They have 6" and 8" diameter tires but it wouldn't fit for your saw.
Aug 13, 2013 | Saws
Tire comes off of wheel
This could be a big wild guess on how the tire comes off on the wheel. But I'll try to help you this thing. I don't know if your bandsaw has adjustment bolt above the upper wheel and below the lower wheel, but in case there is , use these bolts to center the band saw. Well, this could also be blade tension adjustment. Tires should be a very tight fit and a struggle to get on.
Wait, was tired glued on? If not, reglue.
Is that an old tire? If yes, tire must be well worn out and time to invest new ones.
I recommend you to use this time urethane tires rather than rubber tires.
Rubber tires works fine but urethane tires last longer and doesn't need gluing. When you purchase a new tire, make sure that it is a couple of inches smaller than the wheel to stretch the tire. It is a good advice to slightly tilt the top of the drive wheels towards you. I've been purchasing urethane tire with www.bandsawparts.com. Got one from them and still up running. Piece of advise also,Before installing the new tires, you double-check the surfaces of the pulleys to make sure the surfaces are clean and true.
Nov 03, 2012 | Saws
Need new rubber for my band saw wheels, model # 429.24250, dont know where to get them or if I still can?
What is the brand of your band saw? Well, regardless of the brand, you can find aftermarket replacement band saw parts online. I got my rubber tires from this site: http://bandsawparts.com.
Sep 23, 2012 | Craftsman Old Band Saw Bottom Wheel...
CRAFTSMAN BAND SAW 41815 WHEEL TIRE KEEPS COMING OFF
Check the tires maybe it's worn out. If it is, change the tires. I recommend to glue the tires whether it's urethane or rubber. You can try this site for replacement band tires: www.bandsawparts.com.
Aug 08, 2012 | Craftsman 41815 Wheel Tire
My husband has about a 50 year old Craftsman Band Saw, Model # 103.24280 and needs new tires for it. The Wheel number on one is T 41211-103 and on the other is B 41213-103. I called the Sears Parts...
Hi Judy,
I am not a expert on this exact saw but I may be able to help. The good thing is that there is a ton of info. and help with older saws.
You have a 12" saw, this means that the wheels are 12" in diameter. the tires they sent you may have been the right ones ( they are smaller than the wheel and can be a real pain to put on ) the reason for them being smaller is so when the tires are on the wheels they don't slip.
Heres some places you can check.
- carter products ( www.carterproducts .com)
- bandsawtires.org
Look at these 2 sites to get you started, I would also look at "how to install a bandsaw tire" (just type that in ) this will give you a video on how to install a tire. Its alot easier to see it than having someone try and tell you.
You will need to know your width of tire i.e. 3/4"or1"
The saw you have is a Craftsman Model 103, 12" saw (they will ask you this also.
I really hope this helps in some way, The saw you have is a GREAT, I have a Model 113 and use it all the time.
If you have time to leave a comment I would be thankful.
Shop Dog
Dec 29, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
The saw blade will not stay on the wheels even when properly tensioned. Do I need new rubber "tires" The saw is quite old.
you might what you can do first is reverse them by that I mean taking both off the turning them 180 degrees and reinstalling them. Also look at the pulley bearings to make sure not worn excessively.
Mar 06, 2010 | Craftsman Saws
Blade will not stay on wheel
the rubber tires could be worn or the adjustment control is not set correct, you can try removing and reversing the rubber tires first. Let me know and I would need the exact brand and model number to come up with parts disgrams.
Jan 03, 2010 | Craftsman Saws
I have a 12 inch Sears/Craftsman band saw. I got
that is where I would look first, you would need your model number and go to Searspartsdirect.com and type in your model number to find and order the replacement rubber tires and that should take care of your problem
Dec 16, 2009 | Craftsman Saws
Saws Logo
533 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
