Question about Dishwashers
Clen light goes off and on. Unable to get it
"clean" light blinks off and on
Unable to get disherwasher turned on.
Can get the "cancel" lightto come on for a short while . Clean light goes
off and on. Unable to get it turned on
Have checked the circuit breaker.
Have checked if any problem inside of dishwasher is not working
  • 220 Answers
If you push Heated dry<>High temp wash<>Heated dry<>High temp wash  you will reset the control and it will work,but will come back most likely on the next cycle.
 Your issue is in the heating circuit Usually the Heating element but also can be the turbidity sensor,you can ohm the heater and see if it's good if so replace the sensor.
Posted on Sep 06, 2009
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Disherwasher will not start
Are you sure it is the Dry light that is lit, or is it the little Lock symbol located ABOVE the Dry button that is lit? If it's the latter, you can turn off that light (turn off the control lock) by pressing and holding the Dry light for 4 or 5 seconds until that light goes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 04, 2014 | Frigidaire Dishwashers
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
Hpdeskjet problem
A light blinking under the cancel button usually indicates a problem with the color cartridge.
Go to this page for instructions on resolving that issue - about halfway down the page is a picture of your printer control panel with both the left and right light blinking. The section explains that it's to help if "One or both print cartridge status lights are on and blinking."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368924&cc=us&lc=en&dlc=en&product=3374277
Jun 04, 2010 | HP DeskJet D2560 InkJet Printer
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
