Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell pro heat will not extract water from the carpet
Bissell pro heat 2X will not extract water from the carpet. Everything is is great
  • 25 Answers
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Posted on Sep 18, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x doesn't extract dirty water from carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
uyiyio
Jul 04, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 2x pro heat will not **** water out of my carpet
Try turning the dial on the front that says tools. That solved the same problem for me!!!!
Apr 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
611 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
