Question about Chamberlain Standard Duty Polisher/Waxer
How do you remove the foam from the waxmaster?
The foam that holds the cloth on the waxmaster 900 came off. When I try to undo the bolts that holds it there it just keep turning. How do I remove it?
  • recholet Sep 28, 2009
    Thanks but there is a slot in the holder of the foam which permitted me to unscrew the bolt. Unfortunetaly I was not able to find a replacement so I glued that one back on. It should hold for a while. Thanks again.
  • David Ford
    David Ford May 11, 2010
    are you trying to loosen them by hand and if so do you have a cordless driver drill?? If so get a glove and try to loosen with the drill to shock/loosen the bolts.
    Welcome Back:
    Visited the website for 2 consecutive days.
First off, it's a left-handed thread. I wedged the plastic part with a screwdriver to stop it from moving. Get a socket that fits the hex head and turn (counter-clockwise when facing the bolt head). It came off pretty easy. The problem is a replacement, I couldn't find it. I used 1300l glue to re-attach. I then took a hot glue gun and filled the seam between the plastic pad and foam (the entire circumference). Any industrial glue from a hardware store may work. I must admit, I haven't tried the fix yet, although it seems pretty solid. That's how they are attached at the factory, clear glue.
Posted on Sep 26, 2012
  • Dennis Beckett
    Dennis Beckett Sep 26, 2012
    I'M SORRY, TURN CLOCKWISE TO REMOVE.......
  • Dennis Beckett
    Dennis Beckett May 11, 2014
    Here it is 2014, and the pad is still working. I use it on my boat and two cars. The hot glue fix has worked two years. I bought the hot glue gun with a bunch of glue sticks for $10.00 at home depot.
    Welcome Back:
I inserted a screwdriver in a slot of the holder and unsrewed it, counterclockwise. I could not find a replacement so i glued it back on.
Posted on Sep 28, 2009
How to remove the 3 bolts off the torque converter?
come up from behind the engine and undo one bolt
turn the flex plate by hand and undo the second bolt
turn it again and undo the next bolt
pull the torque converter back towards the transmission and keep it in place as you pull the transmission back
Dec 04, 2015 | Cars & Trucks
How do you remove starter motor on 1986 Harley Davidson Softail Custom
First, DISCONNECT THE BATTERY NEGATIVE TERMINAL!!!!
Drain primary fluid, remove outer primary cover.
On the bolt holding the starter gear on, flatten the tab on the lack washer, and remove the bolt.
I use a flat blade screwdriver behind the gear, and hold it out to engage the teeth of the clutch shell to keep it from turning while undoing bolt.
If you're completely removing starter, undo the wiring going to it.
If you just need to move it a little out of the way, you might be able to leave the wires attached.
Remove two bolts holding starter to back side of inner primary cover.
Pull starter out, turning as necessary to clear.
May 07, 2014 | 2004 Suzuki GSX-R 600
How do you get the wheel bearing off a 1996 saab 900
assuming its a front one disconnect lower arm by undoing ball joint bolt remove brake caliper and disc disconnect hub from strut undo driveshaft nut and remove driveshaft u then split hub by pushing centre iut with a press,once split push bearing out with press then push new bearing in and refit everything the same way u removed it
Apr 14, 2010 | 1996 Saab 900
The fan is on and the heat is turned on just not getting hot
You should check a few things here.
Check the hoses going into the heater core from the back of teh engine (underneath the throttle body).
Check the Thermostat guage and make sure it is not faulty.
Replace the coolant in your car. (undo the plug at the bottom of the radiator and let the fluid drain out) Once drained close the plug and then fill it back up with approved coolant)
Run the car until hot (about 15 mins and then see if there is any hot air coming out)
Bad news will be if your heater core is busted. You shouldn;t wait too long to check this out as a busted heated core (clogged) will eventuallu force the seals open and you will get coolant leaking into your car.
If it is your heater core these are steps i followed to replace mine:
Disconnect the negative battery terminal.
Disconnect the top and bottom hoses from the heater core next to the firewall)
Pull off the steering wheel
Undo the steering wheel bolt.
Undo the 3 screws holding the steering wheel cover in place, unclick them and put to the side.
Undo the centre console
Undo the glove box - you'll need to manipulate the stops on the inside and let it fall to the floor before - undo the two bolts at the bottom.
Remove the Instrument panel, radio, radio frame.
Undo the single screw in the bottom of the casing surrounding the vents control, gently pop out the vent plate.
Undo the 4 screws holding the vents controls in place.
Remove the frames that are holding the vent controls in place (either side of the centre colsoles (or where they were)
Remove the two side vents (push down and pull back).
Remove the two bolts (either side) that are holding the dash up.
Remove the two bolts (bottom left corner, bottom right corner) that are holding the dash up.
Gently pull the dash up and forward to (making sure you don't pull any wires off there guides and place to the side).
Put the dash to the side (resting on the front seat)
The heater core should be sitting in the middle of the dash.
Remove the four bolts (two top, two bottom) and place to the side.
Pull the heater core back and move to the side to clear the holes in the firewall.
Manipulate the heater core to the side and move out through the gap in the dash and the cross bar (it is a tight squeeze but you can get it out)
Installation is the reverse of all the instructions.
when you have finished installing the heater core make sure you bleed the engine with coolant
Top up the radiator - keep the cap off, turn on the engine, turn on the heater on the heater to full, with the engine running keep topping up the radiator as the water runs through the new core...keep doing this until no more water goes through - this last step takes a while so be patient otherwise you will start to drive the car and will have an overheating engine very quickly...
Feb 07, 2010 | 2004 Mitsubishi Lancer
Himself has tried to replace the battery on the 03 frelander. managed to get the top bit holding the battery off but the bolt holding th batery into the clip won't undo - just spins around any ideas?!
If you are talking about the battery clamp bolts turning, then put a screwdriver in the split of the clamp and try to put turning pressure on the screwdriver and at the same time undo the nut of the clamp bolt. Or if you have a pair of mole grips, clamp the bolt head and undo the nut. Worst case , pry the clamp off the terminal and use a hacksaw and cut the bolt in half and remove it , fit a new bolt after. Hope that helps
Feb 04, 2010 | 2003 Land Rover Freelander
How to remove and replacse 2002 mitsubishi lancers heatercord
Do you mean Heater Core???
Feb 01, 2010 | 2002 Mitsubishi Lancer
How do I replace my heater core?
If its anything like my 97 lancer you will need to follow these steps..
Dec 23, 2009 | 2004 Mitsubishi Lancer
Directions on how to remove the alternator on 1989 900 Saab. Does anything have to be removed to be able to get the alternator off. Also, any tricks to get belts off first?
Removing the alternator isn't the easiest job on this car!
The long bolt that allows the alternator to pivot to adjust belt tension ISN'T the bolt to be removed; remove the two bolts that hold the mounting bracket to the engine block. One is at the end of the alternator (away from the belt), the other is above the end of the adjusting bolt, not far away from the first bolt. Slacken the tension off the belt by loosening the adjusting bolt, then undo the two bolts holding the bracket to the engine block.
While you have the alternator off, check the bushings of the tension adjusting bolt; if worn/sloppy they should be pressed out and replaced; it'll extend the life of the alternator bearings.
Saabreur
Jul 09, 2009 | 1989 Saab 900 4 Door
How do i remove the damper rod seat at the base of the stachion,does it tap out.
to remove the damper rod you have to remove the allen bolt underneath the bottom of the fork leg. if you find this just turns try using a wooden broom shank to hold it as you undo the bolt.its best to undo the bolt 1st before you strip the fork springs out. hope this helps
Mar 09, 2009 | 1987 kawasaki GPz 1000 RX
Chamberlain  Standard Duty Polisher/Waxer Logo
1,778 people viewed this question
Top Chamberlain Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Chamberlain Tool and Hardware - Other Expert? Answer questions, earn points and help others
