Question about HP DeskJet F380 All-In-One Printer
As others Fnatastic, used the scan in paint! Thanks
HP Officejet 5610 all in one When i try to scan
If you have windows vista and it comes up with the "no scan options" don't press the button on the printer, go to "start" then "accessories" then "paint". This will open up the windows paint program. Go to "File" then click on "From scanner or printer". It will then scan the document, no more problems
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | HP Office Equipment & Supplies
I don't have the instructions that came with my HPF2200 printer/copier/scanner. I can print and copy, but I do not know how to scan.
You will place the document you want to scan into the printer and inside the system you will go to start, then programs, accessories and paint. from paint you go to file then click on from scanner or camera and your document will be scan and you can print it. Thanks
May 12, 2010 | HP Deskjet F335 All-In-One InkJet Printer
I need to know how to scan documents.
If you are using a computer with a Windows Operating System (XP, Vista, etc., ) I can help. Just follow these directions: (From beginning to end)
1) Make sure that the power to your scanner is On but do not plug your scanner into your computer until instructed to do so by the software.
2) Place the CD that came with your scanner into the CD drive of your computer. Install the software for your scanner and plug your scanner into your computer.
3) Re-boot your computer.
4) After re-boot, place a document you want to scan under the lid of your scanner.
5) Go to:
Start > All Programs > Accessories > Paint (and click on the Paint program.
6) When Paint opens, go to the upper toolbar in the program and click on, 'File' then scroll down and click on, 'From Scanner or Camera.'
(a window will open)
7) Click on the icon for your scanner and then click, 'OK".
8) Choose the type of document you wish to scan and click, 'Scan".
9) Note: Some scanners take a moment to 'warm up' before scanning. If your scan doesn't begin immediately, just be patient.)
10) Your document will be scanned and automatically imported into the Paint program.
11) When you can see the scanned document in Paint, (again) go to the upper toolbar and select, 'File' > scroll down and select, 'Save As' > (your Pictures Folder will open) > type in a name for your document > and click, 'Save'.
12) You can now exit the Paint program and go to your Pictures folder. There, click on your scanned document to view it.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | Office Equipment & Supplies
I've Hp psc 1315 all- in-one. I can print, copy but can't scan. My hp solution center is not working???????????
Probably a driver problem. For Windows XP or earlier, go the HP website and download current driver. For Windows Vista, the driver does not enable scanning. A workaround is to use Paint. To open Paint, select:
All Programs-->Accessories-->Paint
To scan the image, select:
File-->From Scanner or Printer
In the Select Device window, click on the HP printer then click on OK. In the Scan Using HP.... window, select a color option and click Scan. Wait for the image to be scanned in and then use Paint to manipulate the image or save it.
Nov 21, 2009 | Cars & Trucks
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Basic instructions for scaning on a lexmark x1150
Using your MSoffice Word (2003/7) you can simply create a New document and then go to Insert / Picture / From scanner or Camera
select TWAIN scanner and satrt scanning from PC (have your document in Lexmark scanner Tray in).
Accept or modify settings.
Resize or change properties of adquired picture
save the Word Document.
You can also use your Picture processing program (Paint or other)
Open Paint (or Other) Go to file /adquire/ select your scanning device Scan.
Dec 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  2. Click Paint .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
Cannon MP530
Hey, so if you already have everthing else working, drivers installed and so on. Lets try scanning a document, this should work if everything is installed fine.
press start
select run
(if your using windows vista just hold down the windows key and press r to open the run menu)
type in mspaint
now that you have paint started, click File and from scanner or camera
if a document gets scanned fine, (follow on screen instructions) then we can look at optional software to scan documents, if paint is not enought.
Thanks,
Ekse
Sep 01, 2008 | Office Equipment & Supplies
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
