Question about Toshiba DR410 DVD Recorder
Toshiba DR410 DVD Recorder copying to PC
So I need to copy what I recorded on a DVD-RW to the PC so I can work with it as an avi, mp4 or whatever format. The problem is, when I finalize the dvd and put in my PC drive it show as a Blank/Full dvd. I tried not finalizing it, and now it shows a folder with 2 files 0 bytes each. Is there any way to solve this? It´s a work related thing so I´m kinda in a rush. Any orientation would be greatly apreciated. Thx
SOURCE: Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Posted on Jan 01, 2009
SOURCE: DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Posted on Jan 03, 2009
SOURCE: I have a toshiba DVR-3 Dvd recorder. What format of disc needed
It needs DVD-R or RW format to record.
Posted on Feb 08, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
Posted on May 30, 2009
  • 26 Answers
SOURCE: err-14
http://www.avsforum.com/avs-vb/archive/index.php/t-579864-p-2.html
Hope this helps
Posted on Sep 26, 2009
How do I fix the problem if the empty disc says can't record on this disc?
Try a new / different disk recognized by this recorder. Make sure you're using DVD+RW disks. Others will not be recognized.
Toshiba R410 Specs CNET
Feb 25, 2015 | Toshiba DR410 DVD Recorder
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
When i burn a copy on my recorder it works fine but when i try to play the recording on another machine it wont play;
check to see if the recordings are protected, under settings in the options menu, can the disc be played in a computer? what type of files are being copied to the disc? i.e. are they vob files or avi,mp4,divx?
Mar 12, 2011 | Panasonic DMR-E85H DVD Recorder
How to connect the toshiba to a rca tv with direct tv
do you have dvd in jacks on your rca...direct tv out to dvd in.....(this setup u need to scan for channels on the dvd)..note some premium channels will not record on dvd (will and still record on vhs)
May 29, 2010 | Toshiba DR410 DVD Recorder
What is the setup code for the DVD Video Recorder D-R410KU to control the player with the cable box remote?
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
Feb 06, 2010 | Toshiba DR410 DVD Recorder
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
Need remote code fo tosihba d-r410
1008
I hope this helps !
Apr 04, 2009 | Toshiba DR410 DVD Recorder
Vhs to dvd
Get a TV card (PCI, USB or PCMCIA); plug an AV cable from the back of the VCR to the TV card, then use the software supplied with the TV card to write the input to an AVI file... The playback has to be 1 to 1,
write the AVI to a DVD using any DVD, or VCD creation software... If you want multiple copies copy the DVD, don't re-write it from the source material (it is quicker)... And then delete the source AVI.
If you don't have a TV card but have a digital camcorder see if it supports AV-IN. When you do this I go from my VCR to the camera then to a firewire port on the PC. The camera acts as a bridge. you can burn it with Nero 5.5xx Get very good results this way.
May 21, 2008 | HP Pavilion dv9000z Notebook
Toshiba DR410 DVD Recorder Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
