Question about Sony Dvcam DSR-390P DV Digital Camcorder
Thank you so much for your support regarding 0040 0012 803f 40000025. I was at the point to smash both computer & Cam. I've turned off Kasperky and everything is FINE. You saved me a lot frustration !! Thanks a lot. Johan Steyn, South Africa
Everything is working fine for the first time in 14 months!!! Thanks Fixya!!!
Posted on Sep 07, 2009
Hi I've got a Honda vtr firestorm, I recently
Does the bike still make good power? does it feel like it is missing? I need a bit more info before diognosis, sorry!
Mar 14, 2013 | Motorcycles
Ecm will not communicate on the OBD11 connection to scan for codes
Hi Juanatijerin, Make sure that your vehicle has the sixteen pin connector and that it is OBD2 compliant. It could be fitted with the sixteen pin connector but compliant to OBD1. Check the ECU fuse. If that is okay check the power feed to the unit and the earth connections. Regards John
Oct 15, 2012 | 2000 Daewoo Lanos
I've no manual for my tn65 and dont know how to operate the web cam.
Here are the basic steps to ENABLE your webcam.
Click on Start...Control Panel...Hardware & Sound...Device Manager...Imaging Devices...Webcam...Enable it!
Your Yahoo/Messenger IM video capabilities will work with your webcam!
Hope this helps! Don't forget to rate me...thanks!
Kind regards!
Sep 09, 2011 | Computers & Internet
We are installing a timing chain in our 1995 Jeep cherokee sundown edition for the first time can you please send me the timing gear specs the motor is a 4.0 with air. thank you
By :"specs" I assume you need install position? To index the gears, whne you take it apart, turn the crank pulley 'till the timing mark aligns with the "0" on the timing scale. Don't turn the crankshaft again. When you are ready to install the chain, locate the mark on the crank gear and align the mark on the cam gear so they point to each other. The mark on the crank gear should be at 12 o'clock and the cam gear mark at 6 o'clock. Make sure when you put the cam gear on the cam that the location pin fits into the gear to position it correctly. Jeep recommends that after putting the chain and gears on, you rotate the engine by hand and place the crank mark at 6 o'clock and the cam gear at 3 o'clock, then count the number of pins in the chain (pins, not links) between those two points. There should be 15 pins. If you are rebuilding the engine and have the cylinder removed, it's a good time to check the front crank pulley (some have the outer ring move on the rubber). Put a piece of flat steel across #1 cylinder with a bolt through the steel extending into the bore center. Turn the engine by hand 'till the piston contacts the bolt. Make a mark on the pulley and turn the engine in the opposite direction till contact is again made. Your timing mark on the pulley should be exactly between the two marks you made. If not, make a new mark at that point and use that as your actual TDC reference. If it is radically off, replace the pulley.
When setting up cam position I always use a degree wheel. If you are installing an aftermarket cam
its important to do that. If you're just replacing a stock chain, You will be fine with the method I've outlined.
May 16, 2011 | 1995 Jeep Grand Cherokee
Can't activate my kasperky waht should i do?
HI
You need a valid avtivation key or key file to activate your product via internet
The key has to be purchased from kaspersky labs
Mar 02, 2010 | Kaspersky Labs Kaspersky Anti-Virus...
Hi i have a 2000 express van 3500 5.7 and did a flex plate on it and smashed the three distubuter wires in between the bel hoseing and trans now im not geting any spark at all.changed the moldel on the...
If you repaired the wires that were damaged to the CAM SENSOR,you might need to replace the ENG 1 fuse. Its a 20 amp fuse.
The wires can break inside of the plastic case, try to stretch the wires at the point where they were flattened.
Dec 14, 2009 | 2000 Chevrolet 3500
Recording Error
I tried everything from deinstalling codecs to alter burning speeds!
My solution to this problem is:
It is essential to
DEACTIVATE the ANTIVIRUS PROTECTION
for the time, the dvd will start to burn.
I use Kasperky Antivirus 8.0.
Jun 28, 2008 | Video Cameras
Sony Dvcam DSR-390P DV Digital Camcorder Logo
612 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
