Question about Garden
Bought new battery. It started. I ran it for
Bought new battery. It started. I ran it for about five minutes. Stopped engine. Now no power.
  • 118 Answers
Put a load test on your new battery it my need charged or its not good. Luck to ya.
Posted on Oct 11, 2013
    President:
  • 1,129 Answers
Many times the gasoline in the tank and fuel system is contaminated and must be removed and purged, drain the gas tank by removing the hose going to the carb. and draining into a container, then remove the carburetor bowl located on the under side of the carb. dump the gas then replace the bowl. refill the gas tank and start
Posted on Sep 06, 2009
Brand new, ran for two minutes then died.
Did you put oil in the engine before it was started. If you purchased it brand new take it back from where you bought it. Could be such a thing as a dirty fuel bowl or fuel jet.
Jul 05, 2015 | Garden
My 1999 e320 lost power as I was driving down the freeway. The check engine light came on and it would only go about 25 mph. I stopped, shut the engine off and restarted it a few minutes later. It ran...
Take the Vehicle to a Automotive parts store and they will scan the on board computer, ( for Free ) and retreave any strored Diagnostic Trouble Codes.Then bring the list of Codes back to me and I will Assist you with whatever the problem is. And about the key deal try replacing the starter relay.
Dec 19, 2010 | Mercedes-Benz E320 Cars & Trucks
2000 volvo s80 ran out of gas put gas in but it wont start
Turn the key to full power (but do not crank the engine). You may hear a high pitched whine from behind you - that's the fuel pump running. Leave the key on for about five seconds, then turn it off for a minute. Turn the key on again for another five seconds, and off for a minute. Then turn the key on for five seconds, and then crank the engine.
If your car ran out of gas, you need to run the fuel pump this way to get fuel up to the engine again - all the lines from the tank to the engine are empty, so the pump needs to run to fill them.
If this doesn't work, it's possible that the fuel pump is vapor-locked and will have to be replaced. Some cars are more susceptible than others to this type of failure.
Dec 05, 2009 | 1999 Volvo S80
My 2004 Ram with a Hemi has lost it's power. It won't pull a string out of a cat's ***. It's not that the converter is stopped up. This is a problem that it as had since about 5000 miles. This truck ran...
Drop down tail pipe and try. Sometimes tailpipes are double walled. If you run into freezing water with the tailpipe very hot the inner portion of the tailpipe can totally collapse. I had this problem with a Chevy car twenty five years ago and it took the longest to figure it out. Ran perfect until I ran through the puddle of icy water.
Jul 07, 2009 | 2005 Dodge Ram 1500
Can a weak battery cause a BMW to misfire?
hello, if the vehicle ran with cable off one would ASUME alternator is ok! however, i bad diode in the aletnator would allow it to charge yet have a massive voltage draw as well, almost all of todays parts stores will do a free starting and charging test for you! ......ps a large voltage drop would rob your ignition of voltage causing your miss!.good luck, marty
Jun 07, 2009 | 1985 BMW 3 Series
Car will start, but after a few minutes of driving will shut off
Is the check engine light on, have it checked for codes and you might get a clue
Aug 02, 2017 | 1990 Oldsmobile Ninety Eight
Tines don't turn
There is usuall a shear pin on the shaft so that when it hits something serious it will shear off preventing the engine from being ruined. I would look for a shear pin somewhere.
Mar 28, 2009 | Garden
My son ran the TDI bone dry of desiel fuel and now it will not start
not shore about VW's but on a GM diesel there is a priming procedure that has to be done.
if there is no manual primer try turning the car to the on position (with the engine off) and wait for five seconds and do this at least five times wait for 30 seconds with the key off and then turn the key to on wait five seconds then start.
Oct 10, 2008 | 1997 Volkswagen Passat
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
