Question about Proview PL913S 19" Flat Panel LCD Monitor
LCD monitor stopped working on my CPU but works on my Brother's
I have had my LCD for about 2.5 years now. I was using it with a DVI connection and recently it stopped working when I boot up the computer. The light on the monitor just keeps flashing and nothing ever displays. I switched to VGA (analog) and it worked, but the next day, the same thing started to happen. I decided to test it on my brother's CPU, and his old 15 inch HP CRT monitor on my CPU. Lo and behold his monitor works on my CPU, and my LCD works on his computer. What is the problem and how can I fix it? Thank you.
    Scholar:
  • 53 Answers
Definitely some electrolytic capacitors are blown inside the monitor in power supply module. Open it and observe any of them rounded on top, replace with proper ones.
You see, controller operations with VGA and DVI inputs takes different current from the supply, that's why it may take different time until PWM chip in the power supply will decide it is time to shut down before getting smoked.
Replace capacitors.
Posted on Sep 11, 2009
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
HOW to reset Compaq S2021A LCD Monitot
* Power the monitor off
* Disconnect all cabling from the bottom and/or sides of the monitor (especially the power cord)
* Press and hold the monitor power button down for 5 seconds
* Reconnect only the monitor power cord and either the #1 blue VGA or #2 white DVI (not both from one video card)
* Power the monitor on
* The PC should already be on. The monitor should auto sense the #1 blue VGA or #2 white DVI. If it does not, press the Input Select button and change to #1 VGA or #2 DVI
Jul 02, 2013 | HP Computers & Internet
Dear sir i have a apple cinema display m8149 lcd.i have loss my apple system(cpu) and want to run apple tft with other cpu (intel dvi and vga) tel me the how will conection or explane me where are RGB...
You can run that monitor from a DVI connection but you would need to get an adapter from DVI to ADC and that supplies power to the monitor. DrBott makes an adapter like this called the DVIator (http://www.dviator.com/) that should work for you if you other CPU has DVI out.
Mar 29, 2011 | Apple Studio 17" Flat Panel LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Like many others, after three years one of my
It sounds like the monitor might have switched input modes for some reason. You can use the menu on the monitor to scroll through the DVI and VGA settings to make sure it is using the right method of connection.
Good Luck!
Jesse
Jan 04, 2010 | Samsung 906BW LCD Monitor
Our HPw1907 monitor appears to constantly want to go to sleep. within 1 or 2 minutes when your on the computer...it like goes blank....I've checked all the settings...but nothing seems to indicate a...
I started a thread on my own forum because there is a lot of discussion about this on many forums with no responses from HP and no one seems to mention that they got a replacement despite the massive problem that it is. It is out of order and I don't doubt for a second that HP knows the length of life of the components in their monitors. All of these things are tested and your talking about components used for years. They know the score by now.
http://forum.webtechglobal.co.uk/viewtopic.php?f=50&t=145
Sep 24, 2009 | HP w1907 LCD Monitor
Monitor Problems
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Sep 09, 2008 | Dell E207WFP LCD Monitor
Blank screen
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Mar 27, 2008 | Samsung SyncMaster 740b 17" LCD Monitor
DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Mar 21, 2008 | Computers & Internet
Proview PL913S 19" Flat Panel LCD Monitor Logo
141 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
