Question about Cell Phones
I have an Apple I phone 3gs. I cant attach an image to a text. The attach image icon is missing. Any solutions.
I want to use my tmobile service in my att 3gs jailbroken 8g iphone i believe i need a factory unlock
Yes, You need to unlock your AT&T iPhone 3GS to use with T-Mobile. You can unlock your iPhone 3GS safer and easier through remote unlocking method. You can get the remote unlocking for an iPhone 3GS from www.unlocking4u.com/apple-iphone-3gs/rs6wp9/ at affordable cost. This site is a legit source to rely on accurate unlocking solutions.
Here are the steps for unlocking an iPhone 3GS through remote unlocking method,
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 3GS phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 3GS to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 3GS.
6. Disconnect your Apple iPhone 3GS and reconnect it after 10 seconds.
7. Your Apple iPhone 3GS is now unlocked.
Sep 22, 2012 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Text will not send without photo being attached
Use deffult setting or contac with your service provider.
Feb 01, 2012 | Apple iPhone 3GS Black (16 GB)
Hello my i phone 3gs 32gb cant start and apple is
  • When did the last time you sync your iPhone to your computer? As a result, iTunes should have backed up all contacts, notes through out that syncing process.
  • Try hard reset, hold power and home button at the same time until Apple logo show up then let go of buttons.
  • If it's still not working, you may need to restore the phone, update to latest firmware available, in this case your phone will be wiped out BUT with the above being said, you should be able to restore from back up you have earlier.
Mar 12, 2011 | Apple iPhone Apps
When texting, emailing or accessing internet, my iphone 3gs display goes horizontal and I am unable to do anything vertically
Try resetting the phone by pressing the Sleep/Wake Button and Home Button - both simultaneously after which it restarts with apple icon. This might solve your problem. -- MS Ramakrishna
Oct 14, 2010 | Apple iPhone 3G
My screen on my iphone 3gs has zoomed in and I can only see 4 icons per page and cant sort it out
Hi, this is a feature for the iPhone. You can just zoom it back out again by double tapping the screen with 3 fingers. To switch the feature off, go settings, accessability and turn "zoom"to off. If it is on, double tap with 3 fingers zooms and same zooms out.
Regards
Jim
Jan 28, 2010 | Apple iPhone 3G
Icons and images just get huge without warning. Can't get them back to "normal" size. Rebooting to change anything. Then, it will "jump" to different apps, also without warning, almost like someone else...
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off,
go to settings, accessability and turn off zoom feature.
Hope this helps and if so please vote.
Thanks
Jim
Dec 07, 2009 | Apple iPhone 3G
Icons are very big
Check if zoom is on, go to "Settings"> "General">Accessibility and switch zoom to "Off"
Hope this helps!
Aug 27, 2009 | Apple iPhone 3GS Black (16 GB)
Iphone icon enlarged
My wife just had this same problem. The entire screen gets zoomed in to where the icons are large. I found that it is a 3-finger double tap function that causes this.
Try double tapping your screen with 3 fingers simultaneously and see if this fixes your problem.
Aug 10, 2009 | Apple iPhone Smartphone
Cant see attachments on iphone 3gs
Usually all the attachments in e-mails are at the very bottom of the email that you receive. From there you will click on the attachment and download it to the phone. Then you should be able to open the attachment after it is downloaded and view. Hope this helps!
Jul 08, 2009 | Apple iPhone 3G
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
