Question about Homelite Garden
Would like to find out how to set carb hi/low speed on homelite mod ut 08030 leaf blower
  • 143 Answers
This is not difficult but it takes patience. First screw both screws in full, then unscrew them out one full turn each.
Start your engine and working on the low screw first adjust it along with
the throttle control screw until you have ticking over nicely, then do the same with the H screw. Make your adjustments very little at a time. Stephen
Posted on Sep 06, 2009
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
My homelite leaf blower UT # UT08023B is running badly all of a sudden. when i pull the trigger to get it to full speed, it acts like it doesn't want to get to full speed only about half speed and it seems...
Its a fuel delivery problem. Its running lean.
Check the fuel line in the tank to see if the filter fell off. If the filter is loose in the tank than the best way to repair is to replace the fuel line. Also the diaghrams in the carb are dry or the screen is clogged. Lastly, if the fuel lines are not rotted and the screen in the carb is clear and everything is in proper working order then you can adjust the carb ( if it has adjustments). Start by turning the low speed needle out ( counterclockwise) 1/2 turn.
Nov 20, 2009 | Homelite Garden
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Homelite chainsaw mod 4620c will start and windup and die
Sounds like it is getting lean (running out of fuel) then dies. Clean and inspect carb and fuel lines.
Oct 08, 2009 | Homelite Consumer Products Backpack...
Homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Aug 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
167 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
