Question about Kenmore Refrigerators
Replacing a water actuator on a kenmore side by part # 4a6512487
Replacing a water actuator on a kenmore side by side model # 253.44383402 (model JCD-23)
dididsaythat
  • 291 Answers
SOURCE: kenmore side by side ,model no 253.51399101
To access the front of despenser.. most times there is a molding around it the will pop of my Gently prying around it .. screws are behind molding
Posted on Nov 21, 2007
  • 1073 Answers
SOURCE: Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Posted on May 11, 2008
aborcass
  • 2651 Answers
SOURCE: replace water actuator
im assuming you replaced the water actuator,and now cant fit the water hose back into the holder??? try disconnecting the hose under the freezer door hinge, this will allow you to pull extra hose up into the dispenser area, then after remounting the face you can reconnect at the bottom
Posted on Nov 25, 2008
techcrazy
  • 72 Answers
SOURCE: broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Posted on Feb 02, 2009
mgprice
  • 744 Answers
SOURCE: I have kenmore refrigerator model- 253 67172504. water inside
Hi. The problem here is going to be with the defrost drain. Follow tthis link to my tips for full details on fixing this problem. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Posted on Dec 27, 2009
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
I have a kenmore coldspot side by side water comes out dispenser but there is no water flow up to ice maker,also just replaced dual water celanoid
Hello, so you just replaced the water inlet valve correct? Here is a video on how to test the icemaker by removing the cover of the icemaker and connecting the L to the V water should immediatley come from the water inlet valve to the ice tray. If it did not and you heard the water valve actuate then there would be an issue with the icemaker in the unit. click this link http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back Thanks
Rick
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How do i replace a water actuator on a kenmore refrigerator
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0501084-00007.png
its about $70 for the part,....what a jokers
Jan 07, 2010 | Kenmore Refrigerators
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Broken water actuator
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 253.51399101
Maybe this will help .. should be diagram of dispenser http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=25351399101&documentID=P0104005&documentTypeID=PLDM&documentClassCode=PM&titleType=DISPENSER&titleID=00007&
Sep 24, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side ,model no 253.51399101
Sep 20, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Replacing actator-water on kenmore side by side .
the water tray probably just pulls out and there's screws near the base that comes out. up underneath there should be some screws to take out. thhen the unit comes down and out the front. wires and a hose will be coming out with it.
Sep 19, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
422 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
