Question about HP Photosmart C4280 All-in-One InkJet Printer
Why does my hp photosmart c4280 no longer have an option to print
SOURCE: my hp photosmart c4280 all in ne is not printing
"print cartridge missing or not detected" appears in the window and the printer does not print.
Posted on Jan 16, 2009
hashchathy
  • 246 Answers
SOURCE: HP Photosmart c4280 region change
http://www.shopping.hp.com/supmodel/product/CC210A%2523ABA?jumpid=in_r329_search//photosmart+c4280_CC210A
please visit this page and try to solve your problem
Posted on Feb 13, 2009
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
SOURCE: HP Photosmart C4280 will not print text
I resolved this by going to "tools" -> "Clean Print Head".
Posted on Mar 23, 2009
SOURCE: Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Posted on Mar 30, 2009
Clogged print head cleaning tinteiros
This printer photosmart c4280 do not have print head fixed in printer, The print heads are in cartridges, replace with original ones.
Nov 19, 2013 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 will print but it will not scan. It says "USB not connected."
Try reinstalling the driver. Make sure you have the newest driver from www.hp.com/support - search your C4280
Mar 11, 2010 | HP PhotoSmart C4280 Laser Printer
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. The following occurred when I tried to troubleshoot: Network Diagnostics was able to connect to the...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. My HP icons are no longer in menu bar either. When I try to print the HP makes a loud noise and shoots the paper through at rocket speed with terrible print quatlity.
Aug 30, 2009 | HP Photosmart C4280 Aio Printer
Can't get word to print from c4280 but will print from the web
When you select 'Print' from MS Word, what printer is listed? Make sure it is the HP C4280 and make sure 'Print to File' is NOT checked.
Aug 03, 2009 | HP PhotoSmart C4280 Laser Printer
Hp Photosmart c4280 Printing Jibberish, dirvers reinstalled.
You can go to HP's solution center and download a utility that will upgrade the "firmware" of the printer. If the upgraded firmware does nothing to fix it, it is e-waste.
Jul 15, 2009 | HP PhotoSmart C4280 Laser Printer
C4280 HP PhotoSmart Printer, Copier, Scanner
Hi, click on the link below for your mac drivers and other supporting software that you will need for your printer. i would advise to save these important drivers your HDD and transfer them to a CD-R if possible.
CLICK HERE FOR YOUR DRIVERS
May 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
Dec 14, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
