Question about Kenmore Dryers
My Kenmore dryer overheats and blows the cut off. The vent is clear. What is the problem?
  • 612 Answers
Your cycling thermostat is bad. When it goes bad the dryer cycles on your thermal cut off (High Limit)
Please rate solution
Posted on Sep 06, 2009
Kenmore model 110.80754001 doesn't heat but element is good
The problem could be the dryer thermal fuse. It is usually located on the blower housing. If the dryer overheats, the thermal fuse blows to cut off power to the dryer. If the thermal fuse has blown, then generally the dryer won't start. If your dryer drum rotates, but does not heat, then the problem could be something else.
If it is the thermal fuse, it cannot be reset-if the fuse has blown, it needs to be replaced.
If it is the fuse ... it is also important to figure out WHY it blew ... or else the same problem could show up. Sometimes the thermal fuse blow due to a clogged vent. That should be checked.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Kenmore Dryers
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Fde546les0 frigidaire dryer blowing thermal limiters
If the fan is running and all duct work is clear, the control thermostat/s will need replacing as they are not switching the heaters off when up to temperature, the dryer then overheats and the thermal limiters blow.
Aug 03, 2014 | Frigidaire Dryers
41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
Apr 19, 2010 | Kenmore 62802 Electric Dryer
Will dryer still run and heat if one of the thermostats (cycling[internal bias], high limit, and/or thermal cut-off) is faulty? Would it simply 'blow' the thermal fuse (that i just replaced) again?
if the thermal fuse keeps blowing it's because the dryer needs a cleanout.you need to clean out the duct that the lint filter slides into vac out the inside of dryer where the motor is and if you have a shop vac put it on blow and blow off the motor,there's alot of lint stuck inside it that the vac can't get out,you can blow the lint from the back of dryer to the front so you don't have to pull the drum to clean it.if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean out the line,i've blown out bird nests and big balls of wet lint after people told me the vent line was clear also make sure the outside vent is clear no screens or cages if there is remove them all they do is catch lint.do this once a year so you don't have a fire and you won't have to replace parts from overheating,thermal fuse is a safety that will pop if the dryer runs to hot mostly from a clogged dryer
Apr 17, 2010 | Kenmore 62882 Electric Dryer
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
I found a bird's nest in the outside exhaust vent of my dryer yesterday. Now the dryer is blowing cold air out of the vent and will not dry the clothes.
The obstruction in the dryer exhaust vent more than likely caused the dryer to overheat. The most common culprit is your Thermal Cut-Out (TCO). The TCO acts like a fuse and will blow when the dryer overheats. It is designed to protect the heating element. The following link explains how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link and check all possible causes. If you determine the TCO to be faulty, replace the Hi-Limit Thermostat at the same time. These components are often sold as a kit. Failure to do so may result in premature failure of any components you replace.
If you have questions along the way, please let me know. I hope you find this information helpful.
PS The TCO and Hi-Limit Thermostat are mounted on the heater box. The TCO will be on the end opposite the heating element terminals, while the Hi-Limit Thermostat is adjacent to the element terminal leads.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
The problem you describe sounds like an airflow problem. Make sure the vent is clear and if you have a plastic vent hose make sure it is not kinked.
If the vent is blowing freely then it may be a thermostat cutting out to quickly.
Post back and let me know what you find or if you have any questions.
Nov 21, 2007 | Dryers
Dryers Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
