Question about Sony VAIO VGN-A170P Notebook
Sony when i put on my notebook, i see a lot of colors mixed on the screen, when the system tries to boot to windows i get a blue screen.
    President:
  • 2,030 Answers
Sounds like you have one of 4 problems.
1) the screen has gone bad.
2) the cable to the screen is bad or lose.
3) the drivers have become corrupted - try reinstalling them for the video card.
4) the vimbedded video card has gone bad.
Posted on Sep 06, 2009
My Sony VAIO Notebook VPCX11S1E wont boot up anymore. when i try it jyst goes to blue screen. How can i get iSony VAIO Notebook VPCX11S1E it to load up and start up normally.?
It seems that your machine is suffering a fatal error on startup. If the blue screen flashes up with some non-sensical writing on it then that is the error I speak of. This condition can be caused by a faulty piece of hardware, most commonly the hard disk drive in my experience. BUT it can also be just a faulty file in the Operating System on your machine and may not be a hardware problem at all.
Either way, the first ting I would do in your position is to reinstall your Operating System. You are using Windows 7 I see. Windows 7 is a good OS. In order to try to recover your computer you will need an original Windows 7 DVD disk. Insert the disk into the DVD drive and then follow the instructions at this like here...
http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/
Jul 08, 2014 | Sony VAIO Notebook
My compaq nc8000 will try to boot up (only shows window xp, then goes to a blue screen with a lot of dots in it), but first shows zeros all across the screen not allowing you to do anything at all.
Hi, sounds like what is known as the blue screen of death. You can try reseting your operating system to an earlier time, before the problem began, by pressing the ESC or Del key during bootup, this will give you the option to boot into safe mode, from where you can attempt the reset. Or you can insert the CD that came with your compaq and perform a system restore. Both of these options will not remove any saved data.
Oct 11, 2010 | Compaq NC8000 Notebook
I have a aspire one notebook computer i bought last year it boots up to the windows part then it takes me too a blue screen with two computers on the page and the name aspire one what's wrong??? please...
The blue screen (called the blue screen of death) comes up usually when enough hardware has changed that it "flags" the system, telling it not to boot. This is kind of like a voting system, drives count so much, video cards count so much, etc. One way to make the blue screen come up for sure is to move the hard drive from one computer to another. This particular thing overrides all other votes and says "no way." This is because it knows which processor was in place when windows was installed, and if a different one shows up it knows the drive was installed in another computer. This happens on desktops a lot, like when you change video cards too often, and other hardware. I haven't seen it too much on laptops, but it can happen. Usually, if you get a blue screen, you will have to reinstall Windows.
Aug 09, 2010 | Acer Aspire One PC Notebook
Try's to boot up, but goes to small blue screen
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
#1: Use a Windows startup disk
#2: Use Last Known Good Configuration
#3: Use System Restore
#4: Use Recovery Console
#5: Fix a corrupt Boot.ini
#6: Fix a corrupt partition boot sector
#7: Fix a corrupt master boot record
#8: Disable automatic restart
#9: Restore from a backup
pls 4 stars .... :-)
Nov 29, 2009 | Sony VAIO VGN-S150 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Hello, please when i put no my sony vaio notebook, the colors are mixed on my screen, i have changed the screen and the screen cable but the problem is still there
Try taking out one ram stick at a time in between boots. It sounds like you make a bad stick of ram and that is causing video issues. Just a thought.
Sep 06, 2009 | Sony VAIO PCG-K25 Notebook
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Blue screen coming up when reapiring from windows xp boot cd
ur RAM is faulty kindly try this first
if u have 2 chips of RAM installed in ur system try one at a time, install in the upper most slot when inserting one RAM in this way u can trouble shoot which of ur chip is faulty may be 1 is faulty or both might be in that case if u get error on both try to get another for testing of the same specs pls
pls let me know abt the results
pls do rate me FIXYA if i have fixed ur problem
Mar 11, 2009 | Sony VAIO VGN-SZ220/B Notebook
My emachine won't work at all i don't even get the windows picture it keeps going to setup in the blue color then black
Is the monitor plugged in properly?
Can you get to the BIOS? --> Does it display the words on the screen during the boot process before the Windows Splash screen?
I'm not sure what setup in the blue color means. If it's the BSOD or Blue Screen of death then let it cool (power it off) and boot again later. Perhaps a heat issue. If you do actually get it to boot copy your most critical data off the hard drive quickly.
Could be a lot of things.
Jul 17, 2008 | Computers & Internet
Sony VAIO VGN-A170P Notebook Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
