Question about Frigidaire GLER642A Electric Dryer
I moved to a house with a three prong outlet for my Frigidare electric dryer, model number FER341AC0, that has a four prong cord. I bought a new three prong cord but there is no color coding on the dryer connections. I need to know which color wire to hook up where.
  • 574 Answers
The center wire on your new cord is the neutral put it on the center terminal on terminal block the two outside wires are your hot wires put them one on each side of the center one.
Posted on Sep 06, 2009
Testimonial: "exactly the info we needed!"
  • 612 Answers
The three wire goes on the electrical block on the back of your dryer just like the cord is made. If you look at the cord, it's made flat (Most 3 wire cord are made flat, Some are not) The wire in the middle goes in the middle of the block. The two wires to the outside go to the outside of the block. It makes do difference which wire goes on which side as long as the outside wires go to the outside.
Please rate solution
Testimonial: "thanks we got it now and we will be drying clothes tonight!"
I have a Kenmore Elite electric dryer model # 11063932102 that will not start. It was in storage for five months and it had some superficial mice issues on the body, which cleaned up nicely, but now it...
Did you replace just the plug end of the existing cord or the entire cord/plug cable at the dryer connection? You cannot just replace the plug end since the 4th connection is not made it won't work. The easiest solutiuon is to use a 3 to 4 prong adapter. See this video that explains it.
http://www.youtube.com/watch?v=ZBJhkyHSCmo
Nov 02, 2014 | Dryers
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Jun 02, 2012 | Whirlpool LEB6200 Electric Dryer
We just bought a Mini Plus B31 coffeemaker and the cord will not plug into a standard three prong outlet. Other appliance cords do plug into the same outlets.
if you have a four pin plug, check that it is not three phase for heavy electrical use. ask your electrical supplier if your house has three phase, if your house had electric storage heating there is a chance it had three phase to balance the electrical supply to the property this can be dangerous so check please (some old boilers were two or three phase years ago)
Jan 18, 2012 | Dryers
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Feb 19, 2008 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
191 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
