Cannot access the internet through my router. It says that I am connected but will not access the internet My laptop was just restored and I have done everything including entering the ip address, sub net and default gateway numbers. I think there is something blocking access to the internet but I cannot figure out what it is.
  • 1 more comment
  • slavenfive Sep 06, 2009
    mozilla firefox
  • lorenzo carolus May 11, 2010
    turn off windows firewall.check your internet options if its correct configured. u must configure your dns too.
  • Sean Wright
    Sean Wright May 11, 2010
    Who do you have your internet service through?
    Novelist:
  • 148 Answers
Just follow the solution., this happens sometimes just because of some hardware conflict that occurs with the drivers stuff..
so go to Properties of my computer
Now select Device Manager,
Expand the tab "NETWORK ADAPTERS"
Select the ur preferred device, like wireless or wired lan
Now after selecting, make a right click & select Uninstall.
simply uninstall the device, if it asks about removing the drivers, dont do so. simply uninstall the device..
Now, if ur computer automatically searches a new hardware then its k, else restart ur machine..
After its restarted, it will show a tab "NEW HARDWARE FOUND"
Let it do its job, after it shows, "HARDWARE INSTALLED PROPERLY", try surfin now..
hope this works u out, if not, i'll love to hear from u about ur problem..
If u like my post, please rate me up, i really need some good ratings...
Thanks..
Posted on Sep 07, 2009
Testimonial: "Yes, yes yes, your solution worked!!! Thank you so much for your help and I advise anyone who has a complicated computer problem to use this guy!"
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
Please I cannot connected to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
Can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Apr 23, 2010 | HP Pavilion dv6000z Notebook
Laptop can connect to wireless router but not the internet
It could be a conflict with IP adresses. Go to your network connections and right click on wirless connection and go to properties. Scroll down the list to internet tcpip and highlite it. Once highlited go to properties. Then check the set manual ip adress and set it to whatever number you like. leave the bars as is. Do the same to the other laptop but different number.
Aug 03, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Internet Connection from desktop
hey laure
you may need to go to control panel, then internet settings, then hit the connection tab, and make sure the 'never dial a connection' button is clicked. then apply and reboot if necessary. don't mess with the router settings and definitely don't restore factory settings, that'll blank out the ip address and other things.
you should be able to access the web, otherwise the ethernet cable fromj your pc to the router is plugged into the wrong port on the back of the router.
good luck
chris from scotland
01776840273
Dec 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to get laptop to connect to the internet.
I have resolved the problem by doing a system restore. I set the computer to a previous date and this seems to have sorted out the problem. I guess that I may have had a software confliction.
Many thanks.
Nov 27, 2008 | 2wire HomePortal® 1800HW Router...
No signal to my laptop
try to restore the laptop that doesnt work by going to start accessories system tools system restore then restore it a few weeks back try that
Dec 12, 2007 | Linksys Dual-Band Wireless A+G Broadband...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
